[Fdo-trac] [fdo-trac] #984: Garbage SRID values being read on	64-bit Linux
    trac_fdo at osgeo.org
    Fri Oct  2 03:04:45 PDT 2020
 Reporter:  jng                  |        Owner:  jng
     Type:  defect               |       Status:  closed
 Priority:  blocker              |    Milestone:
Component:  PostgreSQL Provider  |      Version:
 Severity:  1                    |   Resolution:  fixed
 Keywords:                       |  External ID:
Changes (by jng):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"8019" 8019]:
 #!CommitTicketReference repository="" revision="8019"
 Fix GdbiQueryResult long value parsing in 64-bit Linux. This was the cause
 of garbage SRID values in the PostgreSQL provider and any other code that
 reads out RDBI_INT or RDBI_LONG values. Fixes #984
Ticket URL: <https://trac.osgeo.org/fdo/ticket/984#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
