[Fdo-trac] [fdo-trac] #995: Open should actually try to GDALOpen the data source in question to test if i
    trac_fdo at osgeo.org
    Mon Aug 16 07:28:38 PDT 2021
i
   Reporter:  jng            |      Owner:  jng
       Type:  defect         |     Status:  assigned
   Priority:  major          |  Milestone:  4.1.0
  Component:  GDAL Provider  |    Version:  4.1.0
   Severity:  3              |   Keywords:
External ID:                 |
 Right now on Open() the GDAL provider will always set the internal
 connection state to `FdoConnectionState_Open`
 The Open() method should at least try to `GDALOpen` the referenced data
 source first.
 Right now this provider behavior means that all GDAL connection tests in
 MapGuide will always pass. You can feed garbage data source strings and on
 MapGuide's end it will still be considered a successful test.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/995>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
