[Fdo-trac] [fdo-trac] #687: GDAL Provider memory leak
trac_fdo at osgeo.org
Tue Feb 23 02:51:14 PST 2021
Reporter: vrifino | Owner: warmerdam
Type: defect | Status: closed
Priority: critical | Milestone: 3.5.0
Component: GDAL Provider | Version: 3.5.0
Severity: 2 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: new => closed
* resolution: => fixed
Comment:
Added this code to a temporary GRFP provider test case and built/ran it in
debug mode with CRT memory leak checking enabled. No leaks were reported.
Assumed this is no longer leaking.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/687#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
