[Fdo-trac] [fdo-trac] #935: Failure stripping PostGIS axis from srid=2000
FDO trac_fdo at osgeo.org
Wed Mar 3 06:56:33 PST 2021
 Reporter:  jng                  |        Owner:  badreddinekaroui
     Type:  defect               |       Status:  closed
 Priority:  major                |    Milestone:
Component:  PostgreSQL Provider  |      Version:
 Severity:  3                    |   Resolution:  fixed
 Keywords:                       |  External ID:
Changes (by jng):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"8099" 8099]:
 #!CommitTicketReference repository="" revision="8099"
 Fix some test failures in the PostGIS test suite
  - Update expected geometry types some PostGIS master files. The recent
 support for curve geometries rendered the previous versions incorrect
  - On a similar theme, update LogicalPhysicalHybridBender.xslt to reflect
 the updated geometry support list for PostGIS
  - Update SC axes test to verify additional corner cases
    - Fix incorrect WKT re-assembly when stripping out axis defns from the
 source WKT. It should be re-assembled with a comma. The absence of this
 comma was the cause of the strange resulting WKT as reported in #935
 Fixes #935
Ticket URL: <https://trac.osgeo.org/fdo/ticket/935#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
