[Fdo-trac] [fdo-trac] #936: MySQL test failure: MySqlFdoApplySchemaTest.TestSchema
trac_fdo at osgeo.org
Tue Mar 9 03:41:20 PST 2021
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: major | Milestone: 4.1.0
Component: MySQL Provider | Version: 4.0.0
Severity: 3 | Resolution:
Keywords: | External ID:
Comment (by jng):
The cause of this failure is due to the (inherited) test case assuming the
underlying data store having a case-sensitive index on `f_classdefinition`
meta-schema table.
This is actually not the case (just like SQL Server). Whether we prescribe
the same fix as SQL Server (define `RDBI_DEF_SSQL` for the MySQL test
runner) or something different is TBD.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/936#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
