[Fdo-trac] [fdo-trac] #990: Update our internal OpenSSL to 1.1.1k
trac_fdo at osgeo.org
Fri Mar 26 04:49:38 PDT 2021
Reporter: jng | Owner: jng
Type: task | Status: closed
Priority: major | Milestone:
Component: Thirdparty Components | Version:
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"8121" 8121]:
#!CommitTicketReference repository="" revision="8121"
Merged revision(s) 8104-8120 from sandbox/thirdparty_updates_2103:
* Update OpenSSL to 1.1.1k. Fixes #990
* Add basic WFS test suite. Fixes #989
* Update CURL to 7.73
* The SQLite provider, when compiled in GCC 9 causes a failure in the
TestSelectWithIdtNames test case. Further debugging showed that
SltReader::GenerateUniqueName() was not generating the proper numerical
suffix code. This commit makes the suffix generation slightly more verbose
and explicit, which causes the test case in question to pass again
* Tidy up some leaks and uninitialized vars in the KgOraUnitTest runner
* Have getdistro.sh fallback to 'generic' if getdistro.sh fails because
lsb_release is not installed
Ticket URL: <https://trac.osgeo.org/fdo/ticket/990#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
