[Fdo-trac] [fdo-trac] #989: Add basic WFS test suite
    trac_fdo at osgeo.org
    Fri Mar 26 04:49:38 PDT 2021
 Reporter:  jng           |        Owner:  jng
     Type:  task          |       Status:  closed
 Priority:  major         |    Milestone:
Component:  WFS Provider  |      Version:
 Severity:  3             |   Resolution:  fixed
 Keywords:                |  External ID:
Changes (by jng):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"8121" 8121]:
 #!CommitTicketReference repository="" revision="8121"
 Merged revision(s) 8104-8120 from sandbox/thirdparty_updates_2103:
  * Update OpenSSL to 1.1.1k. Fixes #990
  * Add basic WFS test suite. Fixes #989
  * Update CURL to 7.73
  * The SQLite provider, when compiled in GCC 9 causes a failure in the
 TestSelectWithIdtNames test case. Further debugging showed that
 SltReader::GenerateUniqueName() was not generating the proper numerical
 suffix code. This commit makes the suffix generation slightly more verbose
 and explicit, which causes the test case in question to pass again
  * Tidy up some leaks and uninitialized vars in the KgOraUnitTest runner
  * Have getdistro.sh fallback to 'generic' if getdistro.sh fails because
 lsb_release is not installed
Ticket URL: <https://trac.osgeo.org/fdo/ticket/989#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
