[Fdo-trac] [fdo-trac] #993: OpenSSL: Use "make install_sw" instead of "make install"
trac_fdo at osgeo.org
Thu May 27 04:08:14 PDT 2021
Reporter: jng | Owner: jng
Type: enhancement | Status: closed
Priority: major | Milestone:
Component: FDO API | Version:
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"8137" 8137]:
#!CommitTicketReference repository="" revision="8137"
Use install_sw target instead of install for OpenSSL build. This will skip
over installation of HTML documentation and on the machine which I'm
building FDO on, shaves off nearly a minute from overall end-to-end build
times
Fixes #993
Ticket URL: <https://trac.osgeo.org/fdo/ticket/993#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
