[Fdo-trac] [fdo-trac] #999: Build failures in Ubuntu 22.04 LTS
trac_fdo at osgeo.org
Thu Aug 18 08:49:45 PDT 2022
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: major | Milestone:
Component: Build System | Version:
Severity: 3 | Keywords:
External ID: |
Building FDO when trying to use all available system libs fails in Ubuntu
22.04 LTS due to the following environmental/lib changes:
FDOCommon:
* System `xalan-c` is now `1.12`, which removes several macros that break
compilation of `TransformerXalan.cpp`
* Usage of `FILE` internal implementation details for testing read/write
capabilities in `FdoIoFileStream` that are no longer valid in this
environment.
MySQL Provider:
* System `libmysqlclient` no longer ships the `my_global.h` header and no
longer defines `my_bool` (see:
https://dev.mysql.com/doc/relnotes/mysql/8.0/en/news-8-0-1.html#mysqld-8-0-1-compiling)
OWS:
* References to the long deprecated `std::auto_ptr` that should now be
`std::unique_ptr`
WMS/WFS Provider:
* Link failure on `pthread_nonshared`. We can probably just get rid of
these link references.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/999>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
