[Fdo-trac] [fdo-trac] #998: WFS DescribeSchema fails on landvic service
trac_fdo at osgeo.org
Tue Oct 4 01:13:50 PDT 2022
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: major | Milestone: 4.1.0
Component: WFS Provider | Version: 4.1.0
Severity: 3 | Resolution:
Keywords: | External ID:
Comment (by jng):
Regarding your question, we can answer that with extra unit tests. If we
can make a feature schema with the following classes:
* `Foo`
* `Foo_`
And dump to xml and load that xml into a new one and get the same set of
classes, that's a good enough proof for me that FDO will only ever append
`Type` and not `_Type` to every class name and we should be able to safely
drop the `_Type` XSL transformation rule.
I'll be adding these tests shortly along with a full landvic WFS/WMS test.
If everything passes with the dropping of the `_Type` XSL transformation
rule, then I'll consider that as the fix.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/998#comment:8>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
