[Fdo-trac] [fdo-trac] #1003: Materialized Views not filtered
FDO trac_fdo at osgeo.org
Tue Jun 27 09:19:20 PDT 2023
 Reporter:  dfanetti          |        Owner:  jng
     Type:  defect            |       Status:  new
 Priority:  major             |    Milestone:  4.1.0
Component:  PostGIS Provider  |      Version:  4.1.0
 Severity:  3                 |   Resolution:
 Keywords:                    |  External ID:
Comment (by dfanetti):
 Hi jng,
 the problem is that all materialized views present in all schemas are
 returned. In fact, the filter is performed only in the first part of the
 query and not in the second after the union. To give you an example, the
 query that is performed on the
 my database searching for a view 'view_particelle' on schema 'catasto':
 SELECT  t.table_schema  || '.' || t.table_name AS name,
 lower(t.table_type) AS type,  convert_to(t.table_schema,'UTF8') as
 collate_schema_name,  convert_to(t.table_name,'UTF8') as
 collate_table_name
 FROM information_schema.tables AS t
 WHERE t.table_schema not in ( 'information_schema' ,'pg_catalog')  and  (
 (t.table_schema = 'catasto' and t.table_name = 'view_particelle') ) AND
 t.table_type IN ('BASE TABLE','VIEW')  AND t.table_name not in (
 'geometry_columns', 'geography_columns','spatial_ref_sys',
 'raster_columns', 'raster_overviews')
 UNION
 SELECT ns.nspname || '.' || c.relname AS name,  'view' AS type,
 convert_to(ns.nspname,'UTF8') AS collate_schema_name,
 convert_to(c.relname,'UTF8') AS collate_table_name
 FROM pg_class AS c  JOIN pg_namespace ns ON c.relnamespace = ns.oid
 WHERE c.relkind = 'm'  ORDER BY collate_schema_name, collate_table_name
 ASC;
 The result of the query is a set of 5 rows: one is the the view that I
 requested, the other four are all the materialized view that are in the
 database (4 materialized views in my case, even in other schemas).
 Thank you.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1003#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
