[Fdo-trac] [fdo-trac] #1026: Security hardening sweep
FDO trac_fdo at osgeo.org
Fri Nov 13 06:51:51 PST 2026
 Reporter:  jng      |        Owner:  jng
     Type:  task     |       Status:  closed
 Priority:  major    |    Milestone:  4.2.0
Component:  FDO API  |      Version:
 Severity:  3        |   Resolution:  fixed
 Keywords:           |  External ID:
Changes (by jng):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"8437" 8437]:
 {{{#!CommitTicketReference repository="" revision="8437"
 #1026: Fix the buffer overflows and input-validation gaps a security sweep
 found
 A code-reading sweep of FDO - core, utilities and every provider that
 builds
 on Linux, the vendored SQLite 3.3.13 included, and nothing else from
 Thirdparty - turned up 48 places where a value from an untrusted boundary
 reaches a sink unchecked. This is the fix for all of them. None of the
 changes
 moves the provider-facing ABI: no shipped class gains, loses or reorders a
 member, so the surface the SDK installs keeps its shape.
 Parsers (filter/expression lexer, WKT lexer, constraint lexer)
 FdoLex::getword() documented its maxCharacters parameter and then ignored
 it,
 copying the token into the caller's 4000-wchar stack buffer with no bound.
 A
 filter is client text - MapGuide's SELECTFEATURES passes the FILTER
 parameter
 straight to FdoFilter::Parse() - so a long enough identifier wrote past
 that
 buffer. getword() now refuses a token that does not fit
 (PARSE_5_STRINGTOOLONG), getdigits() takes an end pointer so a caller that
 has
 already written a sign or a radix character is bounded correctly, and the
 dotted-name and quoted-identifier paths append through
 AppendIdentifierPart(),
 which checks the capacity before concatenating: a name like a.a.a...,
 assembled from several tokens into the same buffer, could otherwise grow
 past
 it however each individual part was bounded.
 The heap buffer those paths take from get_string() is owned by a scope
 guard
 now, so a rejected token cannot leak it, and get_string() clears the
 caller's
 pointer when it frees the buffer itself - the callers' own error branch
 was a
 double free as soon as it became reachable.
 The same treatment is applied to the WKT lexer in
 Geometry/Parse/LexFgft.cpp,
 which had the unbounded copy against a 256-wchar buffer
 (FDO_27_BUFFERLENGTHERROR there), and to the constraint lexer in
 Utilities/Common/Src/Parse/Lex.cpp. Its bit and hex string literals are
 sized
 from the declared length and the length is tested before the store; the
 test
 came after it, so an over-long literal was written first and rejected
 second.
 XML reader
 FdoXmlReader is FDO's only Xerces construction site, and it resolved
 external
 general entities. The external-DTD switches it did set
 (fgXercesLoadExternalDTD, and the schema and doctype flags) only cover the
 external subset: a document that declares <!ENTITY xxe SYSTEM
 "file:///...">
 in its own internal subset is well formed, and everything FDO parses - a
 capabilities document, a schema, a spatial context file - can be remote.
 The
 reader sets fgXercesDisableDefaultEntityResolution now, which rejects such
 a
 document. The flag was chosen after reproducing the entity resolution
 against
 a real Xerces build: with the flags the code already had, an entity
 pointing
 at /etc/hostname came back as that file's contents.
 Geometry
 The FGF and WKB parsers read counts out of the stream and used them to
 size
 arrays and bound copies. Fgf/Util.cpp rejects a negative curve-segment
 position count and validates the accumulated ordinate count in 64 bits
 against
 the bytes that are left; Fgf/MultiPoint.cpp does the same for
 numDims*numPositions instead of letting the product wrap;
 Fgf/LineString.cpp
 checks the declared position count against the remaining stream before
 handing
 the array to callers; Fgf/GeometryFactory.cpp gained CheckWkbLength() and
 ReadWkbCount(), so no WKB branch reads a count or copies ordinates past
 the
 end. CoordinateGroup::invertAxis() swaps whole coordinates only, and
 SpatialGeometryConverter's 4-entry ordinate table is bounds checked
 (FDO_17_UNSUPPORTEDDIMENSIONALITY) because the index comes from an FGF
 header.
 Common and the expression engine
 FdoStringP::IsNumber() copied the string into a 1000-byte buffer with
 strcpy,
 with the length test that guarded it commented out; it scans the string in
 place now. FileStream's wide-to-narrow mode buffer was sized from the file
 name rather than from the mode, and both conversions are snprintf.
 TOSTRING
 and TODATE wrote past their fixed 500-entry format arrays, the latter's
 token
 counter also being reused across calls without being reset; both refuse a
 format specification that needs more than 500 tokens.
 RDBMS providers: SQL injection through a filter
 A function's name reached the generated SQL verbatim -
 ProcessFunctionName()
 appended expr.GetName() - and the filter grammar takes that name from an
 identifier, which may be delimited, so "x) OR 1=1 #"(1) = 1 was emitted as
 SQL. FdoRdbmsFilterProcessor validates the name first
 (ValidateSqlFunctionName()), which the SQL Server Spatial and PostGIS
 processors call as well, and an aggregate's first string argument is
 emitted
 as a bare keyword only when it is ALL or DISTINCT - anything else goes
 through
 ProcessStringValue() as a quoted literal. MySQL and MariaDB also treat a
 backslash as escaping the closing quote, so the MySQL processor escapes
 backslashes before the quote is doubled.
 A datastore name reached CREATE DATABASE and DROP DATABASE unescaped. It
 is
 delimited as a MySQL identifier with any embedded backtick doubled, from
 the
 raw owner name: GetDbName() is already ANSI-quoted by GetSQLObjectName(),
 so
 nesting it inside backticks would make the quotes part of the database
 name
 instead of delimiters. The metadata reader that looks a schema up by
 datastore
 name escapes it with the provider's own FormatSQLVal() rather than quoting
 it
 inline, and FdoRdbmsPropBindHelper's memset() had its arguments in the
 wrong
 order, which only worked because the struct happened to be value-
 initialised.
 The legacy King providers had no validation at all: filter identifiers,
 function names, ORDER BY identifiers and ApplySchema's table and column
 names
 are concatenated into SQL text. They go through KgOraIsSqlIdentifier()
 now,
 which accepts a plain identifier, a dotted one, or the same with each part
 double-quoted and holding no quote of its own.
 File providers
 SDF: a string's own length field was used as an allocation size and a read
 length with no bound against the record (SDFPROVIDER_110), and a
 property's
 offset and end offset from the record header became a read position and a
 length with no check either - positioning is PositionAtValue() now,
 SDFPROVIDER_111. The fixed-width readers compared m_pos against m_len -
 sizeof(T) in unsigned arithmetic, which underflows for a record shorter
 than
 the field, so a short record passed the test. The R-tree checked its
 record
 size with an assert that release builds compile out (CheckBlobSize()
 throws
 now), and the compare handler read one offset past its array and used the
 result as a length - the array has a slot for the record size now.
 SHP: the shape objects overlay the record buffer and trust the part and
 point
 counts read out of it, and a MultiPatch record additionally needs room for
 the
 part-type array the overlay injects, which the buffer did not have.
 ValidateShapeRecord() checks each shape type's declared counts and its
 part
 indices against the record before the shape object is built, and the read
 buffer takes the extra part-type room. The DBF side rejects a column
 layout
 that does not fit the record, copies a field out of the record before
 zero-terminating it, bounds the width-driven sprintf in SetData(), and
 checks
 the whitespace trim's bound before dereferencing it.
 SQLite: AppendSQuoted() and AppendDQuoted() wrapped a value in quotes
 without
 escaping it, and their output goes to sqlite3_exec(), so an embedded quote
 ended the literal; AppendQuoted() doubles it. Wkb2Fgf() and Fgf2Wkb() took
 neither the input length nor the output capacity; both do now and return 0
 for
 a geometry that is malformed or does not fit. GetFgfExtents() ignored the
 length it was given and now stops at the end of the stream instead of
 walking
 the buffer. SQLiteTable::Drop() formatted the table name into char[128].
 The vendored SQLite 3.3.13 had its page-size validation removed so that it
 could use a 51200-byte page, which is not a power of two: the page size
 taken
 from the file then sized the page structure and every cell offset read
 from
 it, while the pager allocated each page with its own size. lockBtree()
 requires the file's page size to match the pager's (the new
 sqlite3pager_pagesize()) and to be a multiple of 8, and findCell() range
 checks the stored cell offset instead of masking it, which cannot work for
 a
 page size that is not a power of two.
 Transport (WMS and WFS)
 TLS peer verification was disabled for every request, credentials followed
 redirects to any host, and the endpoint a remote capabilities document
 advertises was fetched as given - as was an absolute schemaLocation in a
 DescribeFeatureType response. Verification is on now
 (FDO_OWS_INSECURE_TLS=1
 is the opt-out for a self-signed endpoint), CURLOPT_UNRESTRICTED_AUTH is
 off,
 and FdoOwsDelegate::IsSameOrigin() confines both the advertised endpoint
 and
 the schema imports to the origin the connection was configured for.
 Other providers
 OGR built two statements with sprintf() into char[512] from caller-
 supplied
 names, and the GDAL provider's string-conversion macros allocate their
 buffer
 on the stack from the input length; the first two are std::string now and
 the
 macros refuse an input longer than FDORFP_MAX_CONVERSION_LENGTH
 (GRFP_115).
 The ArcSDE connection copied its connection properties into fixed members
 with
 sde_strcpy() and no bound; they go through CacheConnectionProperty()
 (ARCSDE_CONNECTION_PROPERTY_TOO_LONG).
 Tests
 Three cases cover the safeguards, and each of them fails without its
 change:
 * XmlTest::testExternalEntityNotResolved - a document whose internal
 subset
   declares an external general entity is rejected by FdoXmlReader. Without
 the
   reader change the entity is resolved and the referenced file's contents
   appear in the parsed content.
 * FilterParseTest::testLongTokens - a quoted identifier one character
 short of
   the lexer's 4000-character buffer still parses; an identifier, quoted
   identifier, dotted name or string literal past it is refused rather than
   overflowing.
 * CommonTest::testStringBoundaries - IsNumber() on a 3000-character number
 and
   on the same with a trailing non-digit, plus the length-related
 conversions
   on a 2000-character string.
 Adding them turned up three defects in the harness, fixed here:
 ParseFilter()'s message buffer was a fixed 512 bytes holding two copies of
 the
 filter; the lexer's string reader freed its buffer without clearing the
 caller's pointer, a double free once a rejected token made the caller's
 cleanup reachable; and the SQLite provider escaped a string DEFAULT value
 itself as well as through the quoting helper, so it was stored double-
 escaped.
 Verified on ubuntu22 amd64 against the dbs/docker-compose.yml fixtures,
 Debug
 (ASan/LSan) and Release, each suite run from its build directory with
 LC_CTYPE
 and NLSPATH set as run_fdo_tests.sh does, and the SHP TestData reset from
 the
 sources:
 * FDO Core OK (133), SDF OK (122), SQLite OK (96), OGR OK (58), SHP OK
 (138)
   and MySQL OK (249) in both configurations, with no LeakSanitizer record
 of
   either kind in the Debug run.
 * The run_fdo_tests.sh run in Debug is green for the rest as well: GDAL OK
   (68), Oracle OK (42), PostGIS OK (141), SQL Server Spatial OK (290),
 ODBC
   SQL Server OK (87) and ODBC Access OK (35), none of them with a leak
 record
   either.
 Fixes #1026
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1026#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
