[Fdo-trac] [fdo-trac] #197: acinclude.m4:7: warning: underquoted definition of FDO_HELP_STRING
trac_fdo at osgeo.org
Tue Oct 6 04:14:01 PDT 2026
Reporter: warmerdam | Owner: (none)
Type: defect | Status: closed
Priority: trivial | Milestone: 3.4.0
Component: Build System | Version: 3.2.0
Severity: 4 | Resolution: invalid
Keywords: | External ID:
Changes (by jng):
* resolution: => invalid
* status: new => closed
Old description:
> warmerda at gdal64[52]% ./build_thirdparty.sh
> Configuring FDO Makefiles
> acinclude.m4:7: run info '(automake)Extending aclocal'
> acinclude.m4:7: or see http://sources.redhat.com/automake/automake.html
> #Extending-aclocal
> This occurs on my ubuntu 7.10 system running autoconf 2.61.
> I'll work on a quoting fix. The problem is not serious as far as I know.
> I think it just produces the somewhat alarming warning at the beginning
> of the build but otherwise works fine.
New description:
#Extending-aclocal
I think it just produces the somewhat alarming warning at the beginning of
Comment:
No longer valid as autotools has long been replaced with CMake
Ticket URL: <https://trac.osgeo.org/fdo/ticket/197#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
