[Fdo-trac] [fdo-trac] #1014: Check in doc sources
trac_fdo at osgeo.org
Tue Oct 13 01:21:48 PDT 2026
Reporter: jng | Owner: jng
Type: task | Status: assigned
Priority: major | Milestone:
Component: Documentation | Version:
Severity: 3 | Keywords:
External ID: |
We don't have content sources for the following documentation artifacts:
- The Essential FDO
- FDO Developer's Guide
We will have to de-compile the existing PDF files into some plaintext
format (markdown or rst), check these sources in and then integrate a
documentation build tool to build new documentation artifacts from these
checked in sources.
We already use sphinx-doc for the MapGuide Developer's Guide (content is
rst files). We can do the same thing here.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1014>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
