[Fdo-trac] [fdo-trac] #228: MySQL Defect : Can't retreive tablename in joined query
trac_fdo at osgeo.org
Tue Oct 13 07:58:57 PDT 2026
Reporter: bscott | Owner: danstoica
Type: defect | Status: closed
Priority: major | Milestone: 3.4.0
Component: MySQL Provider | Version: 3.2.0
Severity: 4 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"8399" 8399]:
{{{#!CommitTicketReference repository="" revision="8399"
Fix joined queries reporting indistinguishable column names
A native FdoISQLCommand query that selects a same-named column from more
than
one table reports that one name for every one of them, and
FdoISQLDataReader
resolves a column name to the first column that has it, so every column
after
the first was unreachable by name. That is FDO ticket #228, which asked
either
for a table-qualified name from GetColumnName() or for some other way to
tell
the columns apart. A table-qualified name was not taken: it changes what a
caller receives for every query, it means nothing for a select-list item
that is
an expression (the reporter's own ticket comment gives "table1.column1 +
table2.column2" as the case that rules it out), and it needs a new table-
name
output on the rdbi_describe_slct contract that every driver would have to
supply. The readers already had the disambiguation both interfaces need -
a
repeat of a select-list name gets a "$<n>" suffix, so a join reports
SHARED_COL, SHARED_COL$1, SHARED_COL$2 - and two defects sat behind it, so
the
GenericRdbms path was broken for the second repeat and the King Oracle
path did
not disambiguate at all.
FdoRdbmsSQLDataReader::GenerateUniqueName() wrote the digit of its suffix
with
"*(dest + propsize + 1 + idx) = buffer[idx++]", which reads and increments
idx
without a sequence point; GCC evaluates the right-hand side first, so the
digit
went one slot past the NUL terminator and the name did not change. A two-
table
join therefore reported SHARED_COL and a malformed SHARED_COL$, and
because the
name was never replaced, the retry loop that looks for a name the result
set
does not already use never terminated: a query with three same-named
select-list
items hung in ExecuteReader() indefinitely (the loop's counter was
observed
climbing past 25 with the name unchanged). The same expression in the
sibling
"name too long" branch also left a gap at dest[2]. Both branches now copy
the
digit and advance the index in separate statements.
c_KgOraSQLDataReader, which is the King Oracle provider's own reader
rather than
a subclass of the GenericRdbms one, returned the OCI column name for every
ordinal and nothing more, so its name-to-index lookup reached only the
first
column of a repeated name - the original symptom of the ticket, unfixed.
Because the suffix is produced by the shared reader, the GenericRdbms fix
covers every provider that reads a native query through it (MySQL,
PostGIS,
ODBC and SQL Server Spatial); King Oracle needed its own.
Provider:
* Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.cpp:
GenerateUniqueName() copies each digit into dest with the index advanced
in a
second statement, in both the suffix and the "too long" branch, and the
sequence-point hazard is noted in a comment. The generated names are
unchanged - first repeat "$1", second "$2" - so no other caller of this
reader is affected.
* Providers/KingOracle/src/Provider/c_KgOraSQLDataReader.cpp,
c_KgOraSQLDataReader.h: the
constructor builds a new m_ColumnNames collection that holds the
reported name
of every result set column in ordinal order, via the new
MakeUniqueColumnName(), which suffixes a name that a previous column
already
used (case-insensitively, matching the collection's own lookup). The
recognized-type and SDO_GEOMETRY branches add that same name to
m_SqlColumns,
so the name a caller is given is the name that resolves to its own
column.
GetColumnName() returns the reported name and now range-checks its
index;
it previously passed the ordinal to OCI unvalidated. m_ColumnNames is an
FdoPtr, so the new collection is released with the reader, and only
private
headers changed (the class lives under src/Provider, not the installed
inc/KingOracle tree), so no shipped layout moves.
Tests:
* Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp,
FdoSqlCmdTest.h:
FdoSqlCmdTest::QueryJoinedColumns (new), in the shared provider suite:
three
tables are each given a key_col and a shared_col, one row is inserted
into
each, and a three-way join selects shared_col three times. It asserts
the
reported names are SHARED_COL, SHARED_COL$1 and SHARED_COL$2, that each
name
reads its own column through GetInt32, and that ExecuteReader() returns
at
all. It fails before the fix - with two tables the name is "SHARED_COL$"
and
with three the reader never returns. Registered in the base suite, so
MySQL,
PostGIS, ODBC and SQL Server Spatial all inherit it. The precondition
uses
DROP TABLE IF EXISTS inside a catch: a plain failed DROP aborts a
PostgreSQL
transaction and would poison every statement after it, while the clause
itself
is newer than some servers this suite targets.
* Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.h: a no-op
override of QueryJoinedColumns for OdbcAccessFdoSqlCmdTest, alongside
the
stubs it already has for the other tests that fixture cannot run because
it
has no SQL-command support.
* Providers/KingOracle/src/KgOraUnitTest/SelectTests.cpp, SelectTests.h:
SelectTests::SelectJoinedColumns (new) for King Oracle: the same three-
way
join against Oracle XE 11g, asserting the same three names and that each
reads
its own value. It failed before the provider fix with the second column
reported as SHARED_COL.
* Providers/KingOracle/src/KgOraUnitTest/InsertUpdateDeleteTests.cpp:
AddBatchRow (was MakeBatchRow returning a Detached raw pointer) now
builds the
row of a batch insert into an FdoPtr and adds it from there.
FdoCollection::Add() takes a reference of its own and does not consume
the
caller's, so the reference the row factory made was left with no owner -
11
direct LeakSanitizer records of 32 bytes, one per row of the four
InsertBatch
tests, each anchoring its row's parameter values, their data values, the
FdoGeometryValue and the FGF byte array behind it. This fixes a leak
introduced with r8398's batch-insert tests and leaves their assertions
unchanged.
Verified in the baseline ubuntu22 Debug (ASan) build container against the
dbs
compose MySQL 5.6, PostGIS and Oracle XE 11g. FdoSqlCmdTest goes from OK
(9) to
OK (10) for MySQL and runs OK (9) for PostGIS; the full MySql and PostGis
suites
are OK (249) and OK (140) with no direct leak record and no record whose
stack
refers to the changed code (their LeakSanitizer totals are unchanged at
46236
bytes in 491 allocations and 105212 bytes in 942). KgOraUnitTest is OK
(39) with
SelectTests OK (3), up from OK (2), and its LeakSanitizer total goes from
6284
bytes in 132 allocations (11 direct, 121 indirect) to 0 bytes.
UnitTestOdbc
builds with the new override.
Fixes #228
Ticket URL: <https://trac.osgeo.org/fdo/ticket/228#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
