[Fdo-trac] [fdo-trac] #1000: PostGIS schema tests should try to trim out extraneous schema before comparison
FDO trac_fdo at osgeo.org
Wed Oct 14 05:29:54 PDT 2026
comparison
 Reporter:  jng                  |        Owner:  jng
     Type:  defect               |       Status:  closed
 Priority:  major                |    Milestone:  4.2.0
Component:  PostgreSQL Provider  |      Version:
 Severity:  3                    |   Resolution:  fixed
 Keywords:                       |  External ID:
Changes (by jng):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"8403" 8403]:
 {{{#!CommitTicketReference repository="" revision="8403"
 Trim off unknown schemas before dumped schema comparison for GenericRdbms-
 based provider tests. Only real consumer is the PostgreSQL suite where we
 can trim off non-public schemas to prevent them from breaking tests that
 compared dumped schemas with their golden masters.
 Fixes #1000
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1000#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
