[Fdo-trac] [fdo-trac] #340: SDF Provider defect : Not in and not like has wrong behavior with null values
FDO trac_fdo at osgeo.org
Thu Oct 15 08:51:08 PDT 2026
values
 Reporter:  bscott        |        Owner:  romicadascalescu
     Type:  defect        |       Status:  closed
 Priority:  major         |    Milestone:  4.2.0
Component:  SDF Provider  |      Version:  3.2.0
 Severity:  3             |   Resolution:  fixed
 Keywords:                |  External ID:
Changes (by jng):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"8410" 8410]:
 {{{#!CommitTicketReference repository="" revision="8410"
 Fix incorrect handling of NULL values within an IN condition. This is an
 Expression Engine level issue, so known downstream consumers that delegate
 handling this condition to the Expression Engine have new covering tests.
 Fixes #340
Ticket URL: <https://trac.osgeo.org/fdo/ticket/340#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
