[Fdo-trac] [fdo-trac] #1019: Better handle large chains of OR conditions
trac_fdo at osgeo.org
Wed Oct 21 01:48:45 PDT 2026
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: major | Milestone: 4.2.0
Component: FDO API | Version:
Severity: 3 | Keywords:
External ID: |
Copy from: https://trac.osgeo.org/mapguide/ticket/2751
DeepSeek analysis of the problem:
At the FDO level, there are 2 issues:
1. The SQLite provider has an internal max expression depth of 1000, which
would cause SQLite to error out with "Expression tree is too large" if
given a sufficiently large chain of OR conditions. Fix: Attempt to
optimize this down to an IN(...) clause during FDO filter -> query
translation.
2. FdoExpressionEngine::OptimizeFilter (called by SetFilter) walks the
expression tree recursively, which for really large chains can cause a
stack overflow. Fix: Make the walking non-recursive.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1019>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
