[Fdo-trac] [fdo-trac] #1017: OGR Provider: stop aliasing the connection as its own capability/info/property objects
FDO trac_fdo at osgeo.org
Fri Oct 23 14:02:02 PDT 2026
 Reporter:  jng           |        Owner:  jng
     Type:  defect        |       Status:  closed
 Priority:  major         |    Milestone:  4.2.0
Component:  OGR Provider  |      Version:
 Severity:  3             |   Resolution:  fixed
 Keywords:                |  External ID:
Changes (by jng):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"8419" 8419]:
 {{{#!CommitTicketReference repository="" revision="8419"
 Split OGR provider into one class per root public FDO interface
 implementation. The previous implementation (one OgrConnection
 implementing all interfaces) wreaks havoc on .net managed FDO client
 applications like FDO Toolbox where the previous implementation was the
 prime reason for R6025 pure virtual function call errors and required an
 ugly/hacky _set_purecall_handler suppression.
 Also bring across the SQLite provider atomic refcounting.
 Fixes #1017
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1017#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
