[Fdo-trac] [fdo-trac] #1010: Spatial operations won't match against MultiGeometry instances
FDO trac_fdo at osgeo.org
Mon Sep 21 06:52:09 PDT 2026
   Reporter:  jng      |      Owner:  jng
       Type:  defect   |     Status:  assigned
   Priority:  major    |  Milestone:  4.2.0
  Component:  FDO API  |    Version:
   Severity:  3        |   Keywords:
External ID:           |
 There are various FdoSpatialUtility operator methods do not handle cases
 when the geometry type is a MultiGeometry.
 This means if say a SDF file (or any FDO provider that uses
 FdoSpatialUtility for spatial predicate processing) has a feature with a
 MultiGeometry geometry instance, no kind of spatial query will match that
 feature because of these un-handled cases.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1010>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
