[mapguide-users] Fdo2Fdo
Paul Ramsey
pramsey at refractions.net
Mon Nov 6 14:35:42 EST 2006
Yes, it's a very SDE-esque approach. "There is just one way to store
spatial data in a database: our way." When you control the
horizontal and the vertical, it must be mighty tempting to solve
impedance mismatch problems through a fiat approach. (How does Bill
Gates change a light bulb? He doesn't, he just declares dark to be
the new standard.)
P
On 6-Nov-06, at 11:30 AM, Frank Warmerdam wrote:
> Jason Birch wrote:
>> It believe that what this means in the short term is that it may
>> be necessary to use Autodesk tools to populate it, and that you
>> can not just access existing data. Longer-term, I'm sure that
>> "foreign" schema support will be added to this provider, but I
>> think that this still requires that you keep the metadata in the
>> same data source (possibly in a different schema?). What I would
>> really like to see is a third level of function where all of the
>> mappings are kept internally to FDO without affecting the
>> datasource. I hope that over time FDO will give priority to "on-
>> the-fly" access to my data without making the data store
>> essentially proprietary to FDO.
> Jason,
> I'm with you on this one. I am very frustrated to discover that
> the FDO
> postgis provider won't support access to existing PostGIS
> datasets. It
> seems antithetical to what I think a "data access" api ought to be
> doing
> for me.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://
> osgeo.org
More information about the Fdo-users
