[fdo-users] RE: [mapguide-users] Advanced WMS provider
configuration
Jason Birch
Jason.Birch at nanaimo.ca
Thu Apr 12 23:31:48 EDT 2007
Hmm. Maybe uploading the configuration document doesn't automatically set up the relationship between the feature source and the config document.
What does the ResourceContent (not header) for your WMS source look like after uploading the content?
Jason
Subject: [fdo-users] RE: [mapguide-users] Advanced WMS provider configuration
Hi Jason, thanks for the additional info.
I'm still a little confused on the relationship between the config file attached to the data connection and the mapguide layer. I used the multi-layer XML example to define multiple layers, however how do i then create a new mapguide layer based on the custom commands? If i try to create a layer based off the connection, it simply queries the WMS featureserver again and gives me a list of the featuretypes as usual?
<Layer name="srtm_mag">
<Style name="default"/>
</Layer>
<Layer name="global_mosaic">
<Style name="pseudo"/>
</Layer>
If i can finish this last step it certainly will solve my problems
Chris
More information about the fdo-users
