[fdo-users] Arcsde sdo update
Brad Nesom kidsmake6 at msn.com
Wed Apr 18 12:45:34 EDT 2007
FYI there are new sde binaries and libs for the client with the new 9.2 sp2.
Download the zip and extract to the client install folder.
http://support.esri.com/index.cfm?fa=downloads.patchesServicePacks.viewPatch
&PID=66&MetaID=1269#install-ncWindows
-----Original Message-----
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: Thursday, April 12, 2007 1:01 PM
To: Brad Nesom
Subject: RE: [fdo-users] Arcsde sdo update
Brad,
We are looking into how to retro fit 9.2 support for Map 2008 (if that
is your question).
This will definitively be available in the coming weeks in the
OpenSource side under the 3.2.x branch.
RF
Sent: Thursday, April 12, 2007 10:37 AM
To: Robert Fortin
Robert,
 As I am having difficulty with moving my data from sde binary to sdo, I
am getting particularly interested in the arcsde fdo provider as being
my longer term solution.
I just re-read your post and have found the following information.
http://support.esri.com/index.cfm?fa=knowledgebase.systemRequirements.co
mpat
ibility
I am wondering if it would not be fairly easy to integrate support for
9.2 into the same model that fdo 3.2 is using. As I have been testing
there seems to be no table read access problems or connection problems.
However the functioning part of fdo 3.2 is the field access to numeric,
date, and int32. The only non-functioning part(read only is all I have
tested.) is the string field access. Put simply I cannot see string
fields in sde 9.2 everything is is good.
Is there a possibility that this cold be implemented for an upcoming
release?
Sent: Wednesday, April 04, 2007 8:11 AM
To: Brad Nesom
Map 2008 will have support for sde 9.1.  The ESRI documentation is not
obvious about using 9.1 client component with 9.2 server.  Primary tests
has shown that it will work but that's probably not a configuration we
want to recommand.  At the same time, by the time you will get Map 2008
(pretty soon), you will be able to get FDO opensource version for sde
9.2.
MGOS (and later related release of MGE) will integrate 9.2 provider.
RF
Sent: Wednesday, April 04, 2007 9:00 AM
To: Robert Fortin
We are a subscription map on 2007 right now. I will upgrade when 08
arrives.
I am considering implementing mgos. That is what I am working on here.
We have esri arcgis server advanced enterprise (which means sde, ims,
gis server). We are trying to get more familiar with the technology and
decide what we will implement.
I have a beta site profile but haven't requested the map 08 just because
of time restraints. My 07 connects to my 92sde (unsupported) with the
limitations mentioned earlier.
Brad
Sent: Wednesday, April 04, 2007 7:48 AM
To: Brad Nesom
Brad,
I meant: what app are you using? Map 2008 Beta, MapGuide OpenSource or
MapGuide Enterprise, etc.
RF
Sent: Tuesday, April 03, 2007 10:07 PM
To: Robert Fortin
I am using 9.2 and oracle 10r2.05
From: "Robert Fortin" <robert.fortin at autodesk.com> Yes.  That's one part
of it.  We also didn't want to impose 9.1 client component on the user.
So we are creating a front end dll loaded that will load the correct
provider depending on the presence of the arcSDE components.  It will
try to load 9.2 components first and if it doesn't succeed, it will try
the 9.1 components.
What are you using? we can probably give you something to try out.
RF
   _____
Sent: Tuesday, April 03, 2007 2:56 PM
To: Robert Fortin
Yes I don't have any problem with the connection. The only problem is
that all number fields show up but no text fields do.
So you are just reworking the dlls to link to the new libs?
Brad
   _____
Sent: Tuesday, April 03, 2007 1:01 PM
To: Brad Nesom; fdo-users at lists.osgeo.org
Brad,
Did you try 9.1 client with 9.2 server?
We are working on linking with the 9.2 client libs.  Once we are done,
it should run with 9.1 or 9.2 client component.
RF
   _____
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Tuesday, April 03, 2007 12:39 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Arcsde sdo update
Is anyone planning on updated the arcsde fdo? I still can't access my
text columns on my 9.2 sde data. As far as I can tell everything else is
hunky.
Thanks
Brad
_________________________________________________________________
Mortgage refinance is Hot. *Terms. Get a 5.375%* fix rate. Check savings
https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&se
arch=mortgage_text_links_88_h2bbb&disc=y&vers=925&s=4056&p=5117
More information about the fdo-users mailing list
