[fdo-users] RE: [mapguide-users] MAP3D 2008 and FDO 3.2.1
Greg Boone
greg.boone at autodesk.com
Fri Apr 20 12:55:47 EDT 2007
Yes. These are the correct links for FDO 3.2.1.
Greg
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, April 20, 2007 12:04 PM
To: MapGuide Users Mail List; fdo-users at lists.osgeo.org
Subject: [fdo-users] RE: [mapguide-users] MAP3D 2008 and FDO 3.2.1
Hi Bruno,
This is more appropriate for the fdo-users list; if you reply, please
drop mapguide-users from the list.
If you're using Nabble, you can find fdo-users here:
http://www.nabble.com/fdo-users-f18163.html
As far as I know, there is no open source download of 3.2.1 available.
These have typically been driven by MapGuide Open Source releases, and
we skipped 3.2.1. I think if you need the source for 3.2.1 then you'll
have to pull it from SVN and compile it yourself. This will change in
the future as FDO moves towards more autonomy as an open source project;
all point releases will have downloads available.
I'm not sure which version was in Map 3D (there were a few 3.2.1 tags)
but this might get you started:
http://svn.osgeo.org/fdocore/tags/3.2.1_G044/
http://svn.osgeo.org/fdosdf/tags/3.2.1_G044/
http://svn.osgeo.org/fdoshp/tags/3.2.1_G044/
http://svn.osgeo.org/fdowms/tags/3.2.1_G044/
http://svn.osgeo.org/fdowfs/tags/3.2.1_G044/
http://svn.osgeo.org/fdoarcsde/tags/3.2.1_G044/
http://svn.osgeo.org/fdogdal/tags/3.2.1_G044/
http://svn.osgeo.org/fdordbms/tags/3.2.1_G044/
I'm missing the SL-King Oracle provider and the OGR provider from the
list...
Jason
Subject: [mapguide-users] MAP3D 2008 and FDO 3.2.1
I'm trying to compile sont tools for AutoCAD map 3D 2008 And i can not
find the proper fdo library.
Map3D 2008 is compiled with fdo version 3.2.1 on fdo.osgeo.org there are
only version 3.2.0 and 3.2.2 beta
Anybody knows where i can find these files?
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
