[fdo-users] RE: FDO Environment setup for Shape images in
windows2003 server
Greg Boone
greg.boone at autodesk.com
Mon Aug 20 12:33:20 EDT 2007
Hi Lokesh,
In building FDO, what process did you use? Did you follow the guidelines
outlined in the following links?
http://fdo.osgeo.org/files/fdo/docs/OpenSourceBuild__README.html
http://fdo.osgeo.org/files/fdo/docs/BuildFDOOpenSource/index.html
I recommend reading the links above, getting your environment setup
correctly and then building FDO and the SHP provider from the command
line using the following commands:
1) call setenvironment.bat
2) call build_thirdparty -w=fdo
3) call build -w=fdo -w=shp
Use the -h option on the scripts above to get a full list of build
options
Greg
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of NallaLokeshKumar
Sent: Friday, August 03, 2007 5:26 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] RE: FDO Environment setup for Shape images in
windows2003 server
Hi
Robert
I downloaded the open source fdoshp-3.2.2 from "fdo.osgeo.org" and i
tried
to build that application by using visual studio 2005.
I got the project into visual studio 2005 by using SHP.sln so entire
files
came into the project structure and I run build on the project
after building the application it is giving the following errors
1). Versioning in SHPMessage.dll
2) Updating Assembly Version information for SHP.Overrides.dll
3) FDOUTILITIES , FDO are not found in the environment variables [ but
i
set these in the environment variables].
4). Fdo.h is not found in the directory [ i copied this header file in
all
folders]
so kindly help me by rectifying those problems
And i would like to know i didnt find any documentation in the website
what
is the architecture they are following to observe the results
if u know about the architecture please help me by sending the documents
thanks in advance
Thanks and regards
Lokesh
Robert Fortin wrote:
> Lokesh
> It is unclear what exactly you want to do. Are you using any specific
> application?
> SHP connection is straight forward: set the connection parameter to a
> single shape file or directory of shape files than open the
connection.
> Each shape file will be listed as a class.
> I'm not sure what you mean by Autocad images.
> RF
> From: fdo-users-bounces at lists.osgeo.org
NallaLokeshKumar
> Sent: Thursday, August 02, 2007 2:27 AM
> Subject: [fdo-users] FDO Environment setup for Shape images and
Autocad
> images in windows 2003 server
> Hi,
> Manuel
> this is Lokesh Kumar.N [ mail me lokeshkumarn at infotechsw.com]
> im trying to utilise the Feature Data Objects API for Shape images as
> well
> as for Autocad Images
> can u suggest me what is the environment i have to set to use FDO for
> shape
> and autocad images
> thanks in advance
> thanks and regards
> Lokesh
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
http://www.nabble.com/FDO-Oracle-Provider-for-linux--tf4081316s18162.htm
> l#a11959132
> Sent from the fdo-users mailing list archive at Nabble.com.
l#a11980067
More information about the fdo-users
