[fdo-users] Creating a spatial filter
simon hope
simonh at geobiz.co.nz
Tue Dec 4 21:44:04 EST 2007
Hi Dan,
I tried the following:
//set the geometry fields
qryPropName = new OSGeo.FDO.Expression.Identifier("shape");
//create a geometry from a poly
poly =
(OSGeo.FDO.Geometry.IPolygon)geomFactory.CreateGeometry("POLYGON((176954.045
5914119.79, 1769564.823 5914473.302, 1770089.64 5914474.08, 1770091.198
5914117.454, 176954.045 5914119.79))");
geom = geomFactory.CreateGeometry(poly);
//create the byte array required to create the expression
byteArray = geomFactory.GetWkb(geom);
OSGeo.FDO.Expression.GeometryValue qryGeomVal = new
OSGeo.FDO.Expression.GeometryValue(byteArray);
//create the filter
OSGeo.FDO.Filter.Filter fltr;
fltr = new OSGeo.FDO.Filter.SpatialCondition(qryPropName,
OSGeo.FDO.Filter.SpatialOperations.SpatialOperations_Intersects,
qryGeomVal);
//set the filter on the query command
qrySelect.SetFilter(fltr.ToString());
And I get the same issue - I also tried creating the byteArray directly from
the poly object i.e.
byteArray = geomFactory.GetWkb(poly);
But i get the same message - is it advisable to use this method to create
polygons? i.e from a WKT or is it better to use LinearRings?
Cheers
Simon
Dan Stoica wrote:
> Hi,
> Use a IPolygon instead of IEnvelope.
> Dan.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of simon hope
> Sent: Tuesday, December 04, 2007 2:08 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Creating a spatial filter
> Hello,
> I'm attempting to create a spatial filter against an SDE FeatureClass. I'm
> hitting a problem with the code below:
> byte[] byteArray;
> OSGeo.FDO.Geometry.IGeometry geom;
> OSGeo.FDO.Geometry.IEnvelope env;
> OSGeo.FDO.Geometry.FgfGeometryFactory geomFactory = new
> OSGeo.FDO.Geometry.FgfGeometryFactory();
> OSGeo.FDO.Expression.Identifier qryPropName;
> try
> //create a geometry from an envelope
> env =
> geomFactory.CreateEnvelopeXY(1765068.119,5916635.233,1765756.4,5917101.847);
> geom = geomFactory.CreateGeometry(env);
> //create the filter
> qryGeomVal);
> catch (Exception ex)
> throw new Exception(ex.ToString());
> finally
> //todo clean up
> the code falls over when i try and SetFilter - giving me an error:
> {"'FdoFgfGeometryFactory::CreateGeometryFromFgf': Unknown geometry type
> '769' discovered. "}
> I've managed to create attribute filters, and have tried to follow that
> pattern for a spatial filter - should I be creating a specific geometry
> type?
> Any ideas?
> Cheers
> Simon
> http://www.nabble.com/Creating-a-spatial-filter-tf4941500s18162.html#a14145736
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/Creating-a-spatial-filter-tf4941500s18162.html#a14164229
More information about the fdo-users
