[fdo-users] build_linux errors
Marc Pfister
mpfister at enplan.com
Tue Dec 11 19:49:40 EST 2007
I've been following the directions for installing MapguideOS on Ubuntu
here:
http://wiki.osgeo.org/index.php/Building_Mapguide_on_Ubuntu_6.06_Server
and have been able to successfully build with the Third Party script.
However, when I try to run the Build_Linux script, I get errors in every
single package. They all look something like this:
* g++ -DPACKAGE_NAME=\"FDORDBMS\" -DPACKAGE_TARNAME=\"fdordbms\"
-DPACKAGE_VERSION=\"3.2.2\" "-DPACKAGE_STRING=\"FDORDBMS 3.2.2\""
-DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdordbms\"
-DVERSION=\"3.2.2\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
-DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
-DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
-DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -I. -I.
-I/home/mpfister/fdosvn/Fdo/Unmanaged/Inc
-I/home/mpfister/fdosvn/Fdo/Unmanaged -I../../../../GenericRdbms/Inc
-I/home/mpfister/fdosvn/Utilities/Common/Inc
-I/home/mpfister/fdosvn/Utilities/SchemaMgr/Inc/Sm/Lp
-I/home/mpfister/fdosvn/Utilities/SchemaMgr/Inc -I../../../Inc
-I../../../Inc/Rdbi -I../../ -I../../../ -I../../../Inc -I.././Other
-I.././Capability -I.././Connection -I.././Custom -I.././FeatureCommands
-I.././Filter -I.././Lock -I.././Lt -I.././Schema -I.././SpatialContext
-I/home/mpfister/fdosvn/Fdo/Unmanaged/src/geometry
-I/home/mpfister/fdosvn/Utilities/Common/Inc -I../../Gdbi
-I../../LongTransactionManager -I../../LockManager -O2 -MMD -MT
-DFULLPROTO -D__USE_GNU -DLINUX -MT FdoRdbmsCommandCapabilities.lo -MD
-MP -MF .deps/FdoRdbmsCommandCapabilities.Tpo -c
FdoRdbmsCommandCapabilities.cpp -fPIC -DPIC -o
.libs/FdoRdbmsCommandCapabilities.o
* In file included from
/home/mpfister/fdosvn/Fdo/Unmanaged/Inc/FdoCommon.h:29,
* from
/home/mpfister/fdosvn/Fdo/Unmanaged/Inc/FdoStd.h:25,
* from
/home/mpfister/fdosvn/Utilities/Common/Inc/stdafx.h:72,
* from FdoRdbmsCommandCapabilities.cpp:20:
* /home/mpfister/fdosvn/Fdo/Unmanaged/Inc/Common/Exception.h:26:24:
warning: FdoMessage.h: No such file or directory
* /home/mpfister/fdosvn/Fdo/Unmanaged/Inc/Common/Ptr.h: In constructor
'FdoPtr<T>::FdoPtr(FdoInt32)':
* /home/mpfister/fdosvn/Fdo/Unmanaged/Inc/Common/Ptr.h:93: error:
'FDO_1_INVALID_INPUT_ON_CLASS_CREATION' was not declared in this scope
* /home/mpfister/fdosvn/Fdo/Unmanaged/Inc/Common/Ptr.h: In member
function 'T& FdoPtr<T>::operator*() const':
* /home/mpfister/fdosvn/Fdo/Unmanaged/Inc/Common/Ptr.h:170: error:
'FDO_1_INVALID_INPUT_ON_CLASS_FUNCTION' was not declared in this scope
function '_NoAddRefReleaseOnFdoPtr<T>* FdoPtr<T>::operator->() const':
And so on. You can see the rest of the errors for this package here:
http://pastebin.ca/812747
Any ideas on what's going so wrong?
Platform is Ubuntu 6.06 on an X86-64 system.
Thanks,
Marc
n
Marc Pfister
Geospatial Data Manager
ENPLAN
530/221-0440 x108
530/221-6963 Fax
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20071211/338f526e/attachment.html
More information about the fdo-users
