[fdo-users] Failed to process the given spatial condition
simon hope simonh at geobiz.co.nz
Wed Dec 12 16:17:27 EST 2007
Dan,
I have tested the spatial filter using both the SHP and OGR providers and it
works just fine so I'm pretty sure that its not that. When I saw this issue
occuring via the MapGuide API a month or so ago I was also testing against
SDE 9.2  - a friend was executing similar spatial filters without issue
against SDE 9.1 so I have assumed that the problem is with the SDE 9.2
provider.
I'm fairly comfortable with developing using the .Net binaries but haven't
set up my environment to use or debug the C++ source so I've not managed to
get to the root of the issue  - would it help if I was buidling the release
and debug binaries from source? i.e. to allow me to debug out to the C++?
Cheers
Simon
Dan Stoica wrote:
> Any luck with this?
> Unfortunately ESRI's error code = -1 is generic and I cannot tell what's
> happening.
> Dan.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of simon hope
> Sent: Monday, December 10, 2007 3:07 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Failed to process the given spatial condition
> Dan,
> The InnerException is: {"Operation Failed (-1)"}
> "Can you debug and see exactly where it fails?"
> I'm using the .Net API and it fails when trying to call Execute() on
> OSGeo.FDO.Commands.Feature.ISelectImp
> "What is in the spatial filter"
> qryPropName = new OSGeo.FDO.Expression.Identifier("Shape");
> poly =
> (OSGeo.FDO.Geometry.IPolygon)geomFactory.CreateGeometry("POLYGON((176954.045
> 5914119.79, 1769564.823 5914473.302, 1770089.64 5914474.08, 1770091.198
> 5914117.454, 176954.045 5914119.79))");
> geom = geomFactory.CreateGeometry(poly);
> byteArray = geomFactory.GetFgf(geom);
> OSGeo.FDO.Expression.GeometryValue qryGeomVal = new
> OSGeo.FDO.Expression.GeometryValue(byteArray);
> OSGeo.FDO.Filter.Filter fltr;
> fltr = new OSGeo.FDO.Filter.SpatialCondition(qryPropName,
> OSGeo.FDO.Filter.SpatialOperations.SpatialOperations_Intersects,
> qryGeomVal);
> qrySelect.SetFilter(fltr.ToString());
> Cheers
> Simon
> Dan Stoica wrote:
>> Hi,
>> This is the default error message when ArcSDE returns an error in spatial
>> condition cases. I'm surprised there is no native error message.
>> Can you debug and see exactly where it fails? What is in the spatial
>> filter?
>> Dan.
>> Sent: Sunday, December 09, 2007 3:20 PM
>> Subject: [fdo-users] Failed to process the given spatial condition
>> Hello,
>> I've come across an issue which i think i may have come across before
>> [1].
>> I
>> am using the ArcSDE provider:
>>   <FeatureProvider>
>>     <Name>OSGeo.ArcSDE.3.2</Name>
>>     <DisplayName>OSGeo FDO Provider for ArcSDE</DisplayName>
>>     <Description>Read/write access to an ESRI ArcSDE-based data store,
>> using
>> Oracle and SQL Server.</Description>
>>     <IsManaged>False</IsManaged>
>>     <Version>3.2.1.0</Version>
>>     <FeatureDataObjectsVersion>3.2.1.0</FeatureDataObjectsVersion>
>>     <LibraryPath>ArcSDEProvider.dll</LibraryPath>
>>   </FeatureProvider>
>> I am setting a spatial filter on the select query then attempting to set
>> a
>> feature reader by executing the query:
>> OSGeo.FDO.Commands.Feature.IFeatureReader featReader =
>> qrySelect.Execute();
>> At which point i get an exception: 'Failed to process the given spatial
>> condition'. Has anybody successfully managed to create a spatial filter
>> using the ArcSDE 9.2 v3.2 provider?
>> Cheers
>> Simon
>> [1].http://www.nabble.com/Failed-to-process-the-given-spatial-condition-to13205208s16610.html#a13223966
>> View this message in context:
>> http://www.nabble.com/Failed-to-process-the-given-spatial-condition-tp14242828s18162p14242828.html
>> Sent from the fdo-users mailing list archive at Nabble.com.
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://www.nabble.com/Failed-to-process-the-given-spatial-condition-tp14242828s18162p14260539.html
View this message in context: http://www.nabble.com/Failed-to-process-the-given-spatial-condition-tp14242828s18162p14303971.html
More information about the fdo-users mailing list
