[fdo-users] Can the FDO PostGIS provider use views?
Greg Boone greg.boone at autodesk.com
Thu Dec 20 14:39:56 EST 2007
The patch has been applied.
Thanks,
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of John Pulles
Sent: Thursday, December 20, 2007 3:54 AM
To: FDO Users Mail List
Subject: Re: [fdo-users] Can the FDO PostGIS provider use views?
Jason Birch schreef:
> I agree that the provider should probably give access to spatial views
> also.
> John, regardless of whether you have the resource to fix the problem
> (which would be cool; Mateusz has a lot on his plate), please submit
> this as an issue in our Trac instance:
> http://trac.osgeo.org/fdo/wiki/SubmitTicket
Jason, Greg,
I managed to register for the Trac site and am busy submitting the ticket with patch file attached, but the site is unfortunately a bit unresponse. It should be submitted now, but
http://trac.osgeo.org/fdo/report/1 doesn't show anything.
Today I am unable to build and test the (attached) patch myself, but I will try to do that the coming days.
John.
> Jason
> From: Greg Boone
> Subject: RE: [fdo-users] Can the FDO PostGIS provider use views?
> I am not sure of your background, but I was wondering if you would be
> in a position to develop a patch to fix this issue, test it and post
> it for submission?
> From: John Pulles
> Subject: [fdo-users] Can the FDO PostGIS provider use views?
> For views, the relkind column has a value of 'v', thus views are NOT
> selected by this query. Shouldn't the PostGIS provider enable usage of
> views that are present in the geometry_columns table?
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
John Pulles
Geodan IT b.v.
Buitenhaven 27-A
5211TP 's-Hertogenbosch
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)73 - 692 5150
Postadres / mailing address
President Kennedylaan 1
1079MB Amsterdam
E-mail:  john.pulles at geodan.nl
Website: http://www.geodan.nl
More information about the fdo-users mailing list
