[fdo-users] Spatial Query with MySQL FDO provider
Gavin Cramer
gavin.cramer at autodesk.com
Fri Feb 16 16:07:47 EST 2007
I just tried it by quickly hacking a unit test, and both the POINT and
LINESTRING examples worked for me. I am using MySQL 5.0.24a.
However, I did notice that when I misspelled the property name (it was
supposed to be "Geometry" for the unit test), the resulting error
message was from MySQL, regarding a bad ')'. It was not a complaint
about the column name, nor was it an FDO SQL translation exception about
a property name that you might expect if you created the filter using
C++ objects, e.g. with FdoSpatialCondition::Create().
Is this any help?
Gavin
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of George McLean
Sent: Thursday, February 15, 2007 6:15 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Spatial Query with MySQL FDO provider
I am having trouble writing spatial queries against MySQL 5.0.18 using
the OSGeo.MySQL.3.2 provider
I pass the string 'geometry INTERSECTS GEOMFROMTEXT ('POINT XY (2536400
481800)')' to the SetFilter method of an MgFeatureQueryOptions object.
When I call selectFeatures from a feature service object, I get no
errors.
When I use the filter string 'geometry INTERSECTS GEOMFROMTEXT
('LINESTRING XY (2536400 481800, 2536500 481900)')' I get the following
error on selection:
An exception occurred in FDO component. String does not represent a
valid filter.
As far as I can tell the query string is OK. I have the same problem
with using POLYGON as the geometry as well. Only POINT seems to work.
When I query the capabilities of the MySQL provider it appears to me
that LINESTRING and POLYGON are supported.
Any suggestions?
Thanks
George McLean
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
