[fdo-users] Set "Default" spatial context (MySQL)
Hidekazu Shimaji
hshimaji at ybb.ne.jp
Sat Feb 24 08:53:40 EST 2007
It works.
Thanks a lot.
Hidekazu
--- Jack Lee <jack.lee at autodesk.com> wrote:
> Hi,
> Destroy the default spatial context first and then re-created it.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org on behalf of Hidekazu Shimaji
> Sent: Sat 2/24/2007 3:52 AM
> To: FDO Users ML
> Cc:
> Subject: [fdo-users] Set "Default" spatial context (MySQL)
> Hello,
> I want to know how to set a spatial context named "Default" to a MySQL data store.
> When I set a "Default" spatial context to a data store, which had been just created by
> using
> a CreateDataStore command, a folloing error occured:
> OSGeo.FDO.Common.Exception: Cannot create Spatial Context 'Default', it already exists
> I executed a GetSpatialContexts command, and I recognised that the "Default" spatial
> context
> exactly existed, but its CoordinateSystemWkt property had nothing.
> I'd like to change the CoordinateSystemWkt value because all feature classes use the
> "Default" spatial context. How can I do it? Please help me.
> using
> FDO3.2 (MapGuide Open Source 1.1.0)
> MySQL 5.0.27
> WindowsXP SP2
> Visual Web developer 2005 SP1 (C#)
> my code is folloing:
> ---code start
> //WKT
> const string PROJECTED_WKT =
> "PROJCS[\"MY_CS\",\n" +
> " GEOGCS [\"NAD 83 (Continental US)\",\n" +
> " DATUM [\"NAD 83 (Continental US)\",\n" +
> " SPHEROID [\"GRS 80\",6378137,298.257222101]],\n" +
> " PRIMEM [\"Greenwich\", 0.000000],\n" +
> " UNIT[\"Decimal Degree\",0.01745329251994330]],\n" +
> " PROJECTION [\"Transverse Mercator\"],\n" +
> " PARAMETER [\"Scale_Factor\",0.999600],\n" +
> " PARAMETER [\"Central_Meridian\",\\-75.000000],\n" +
> " PARAMETER [\"False_Easting\",500000.000000],\n" +
> " PARAMETER [\"False_Northing\",{1}],\n" +
> " UNIT [\"Meter\",1.000000000000]]";
> //DataStore name (just created by using a CreateDataStore command)
> const string DATA_STORE = "NewDataStore";
> //craete a CreateConnection command
> IConnection connection = FeatureAccessManager.
> GetConnectionManager().CreateConnection("OSGeo.MySQL.3.2");
> //set properties
> IConnectionPropertyDictionary connectionDictionary =
> connection.ConnectionInfo.ConnectionProperties;
> connectionDictionary.SetProperty("Service", "localhost");
> connectionDictionary.SetProperty("Username", "root");
> connectionDictionary.SetProperty("Password", "password");
> connectionDictionary.SetProperty("DataStore", DATA_STORE);
> //open connection
> if (connection.Open() ==
> OSGeo.FDO.Connections.ConnectionState.ConnectionState_Open)
> //craete a CreateSpatialContext command
> ICreateSpatialContext createSpatialContext =
> (ICreateSpatialContext)connection.CreateCommand(
> OSGeo.FDO.Commands.CommandType.
> CommandType_CreateSpatialContext);
> //name
> createSpatialContext.Name ="Default";
> //description
> createSpatialContext.Description =
> "Projected Coordinate System Test";
> //wkt text
> createSpatialContext.CoordinateSystem = "WKT";
> createSpatialContext.CoordinateSystemWkt = PROJECTED_WKT;
> //tolerance
> createSpatialContext.XYTolerance = 0.001;
> //range of drawing
> FgfGeometryFactory factory = new FgfGeometryFactory();
> IEnvelope envelop =
> factory.CreateEnvelopeXY(0, 0, 1000, 1000);
> IPolygon polygon = (IPolygon)factory.CreateGeometry(envelop);
> createSpatialContext.Extent = factory.GetFgf(polygon);
> //execute the command
> createSpatialContext.Execute();
> Response.Write("default spatial context has been set." + "<br>");
> //close connection
> connection.Close();
> ---code end
> Thank you in advance.
> Hidekazu
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
