[fdo-users] .NET FeatureReader and MySQL FDO provider
George McLean
gmclean at gorge.net
Sat Jan 13 19:58:42 EST 2007
Hello,
I have written an application in .NET that queries a database using an
FDO provider. The application works well when I use the
Autodesk.SqlServer3.1 provider but does some strange things when I use
the OSGeo.MySQL.3.1 provider or the OSGeo.MySQL.3.2 driver.
Specifically, I am having trouble with the GetString method in a
FeatureReader object. When I query data from MySql and loop through the
data set, the GetString method does not appear to clear out the values
from the previous record for the given field. If I have two records with
values of 'ABCDEF' and 'XYZ', the first pass through the loop will set
the value of strValue to 'ABCDEF' but the second pass yields 'XYZDEF'.
It looks like some sort of buffer is not getting cleared and I am
guessing it is in the MySQL provider. This code works correctly with SQL
Server. Any suggestions?
Dim DataReader As Autodesk.Gis.Fdo.Commands.Feature.IFeatureReader
DataReader = FdoSelectCmd.Execute()
While DataReader.ReadNext() = True
strValue = ""
If DataReader.IsNull("a_text_field") Then
strValue = "none"
Else
strValue = DataReader.GetString("a_text_field")
End If
End While
Thanks
George McLean
More information about the fdo-users
