[fdo-users] RE: RE: Defining SpatialContext - how and when?
    Maksim Sestic
    max at geoinova.com
    Mon Jul  9 05:49:55 EDT 2007
Huh, funny thing but "Autodesk.SqlServer.3.1" provider connection
capabilities on SpatialContext report following:
- SupportsCSysWKTFromCSysName: False
- SupportsMultipleSpatialContexts: True
I guess I still need to set spatial context WKT by hand and this setting
shouldn't affect geometries that will get inserted during next stage.
Anyway, I tried three different approaches and all of them failed, raising
"Error
creating spatial context (null) (SRID=486518961), the WKT provided does not
match the catalog." exception:
1) create DataStore, then insert new SpatialContext (with WKT string defined
by hand) and associate schema class geometric properties with newly created
CS (using SpatialContextAssociation).
2) create DataStore, then insert new SpatialContext (without WKT string) and
associate schema class geometric properties with newly created CS (using
3) create DataStore, then delete "Default" spatial context and create a new
"Default" one with different precision and envelope (but without WKT string,
as in it's original settings). Geometric properties, when instantiated
within schema class, are set to "Default" CS by default so I don't need to
manually set them.
The other solution is to convert any MGI coordinate to WGS84 and let them
into the datastore using "Default" CS, but this is actually not a good one
since certain coordinate conversions are "one way only" when talking about
precision. My datastore is supposed to keep GPS-measured coordinates precise
to a few millimeters, while coordinate conversion roundtrip (MGI -> WGS84 ->
MGI) involves overall imprecision measured in meters :-)
Regards,
Maksim Sestic
Gavin Cramer wrote:
> Ah, yes, the WKT...
> WKT only needs to be manually set (using
> FdoICreateSpatialContext::SetCoordinateSystemWkt() for FDO providers that
> cannot generate WKT.  This is the case for most providers (because their
> underlying datastores don't have native coordinate system support).
> For those that do natively support coordinate systems (like Oracle), the
> provider may also verify that the coordinate system name and WKT are in
> the datastore's catalogue.  It's generally just a blind string comparison,
> so minor variations may cause a failure in WKT.  To avoid this, just omit
> setting the WKT attribute.
> There is an FDO capability to let you know whether WKT generation is
> supported:  FdoIConnectionCapabilities:: SupportsCSysWKTFromCSysName().
> By the way, while your code for creating a LineString will work, the
> FdoIDirectPosition type is not yet a pooled object, and will result in a
> lot of heap activity.  I recommend looking at the other constructors that
> are more efficient if you plan to use a lot of features.  For example,
> there is one that takes an array of ordinates.  There are accessors that
> tend to be much faster as well.  For example, GetItemByMembers() is the
> fastest one that does all the ordinate reading for you, and GetOrdinates()
> is the fastest if you want a raw ordinate array.
> Gavin
> -----Original Message-----
> From:	fdo-users-bounces at lists.osgeo.org on behalf of Maksim Sestic
> Sent:	Sat 07-Jul-07 10:28 AM
> To:	fdo-users at lists.osgeo.org
> Cc:
> Subject:	[fdo-users] RE: Defining SpatialContext - how and when?
> Dear Gavin,
> Thanks for the tip. It's still bugging me. Here's what I'm doing:
> 1) create new DataStore named "GIS"
> 2) create SpatialContext named "MGI" using following parameters:
> - Name: MGI
> - Description: MGI
> - Coordinate System: MGI / Balkans zone 6
> - Coordinate System WKT: PROJCS["MGI / Balkans zone
> 6",GEOGCS["MGI",DATUM["Militar_Geographische_Institute",SPHEROID["Bessel
> 1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.000000],UNIT["Decimal
> Degree",0.01745329251994330]],PROJECTION["Transverse_Mercator"],PARAMETER["Centr
> al_Meridian",18],PARAMETER["Scale_Factor",0.9999],PARAMETER["False_Easting",6500
> 000.000000],PARAMETER["False_Northing",0.000000],UNIT["Meter",1.000000000000]]
> - XY Tolerance: 0.0001
> - Z Tolerance: 0.0001
> - Extents Type: SpatialContextExtentType_Static
> - Extents range from 0,0 to 7000000,7000000
> 3) create schema "TESTSCHEMA" containing one class "TESTCLASS" with
> GeometryValue defined as:
> geomProperty.GeometryTypes = 7
> geomProperty.SpatialContextAssociation = "MGI"
> Still, when I try to issue an Insert on some geometry ti throws "Error
> not
> match the catalog." again.
> Here's the geometry definition (sitting within specified spatial context
> extents):
> Dim insertCommand As IInsert =
> CType(m_Transaction.Connection.CreateCommand(CommandType.CommandType_Insert),
> IInsert)
> insertCommand.SetFeatureClassName("TESTSCHEMA:TESTCLASS")
> Dim factory As AgfGeometryFactory = New AgfGeometryFactory()
> Dim pcollection As DirectPositionCollection = New
> DirectPositionCollection()
> pcollection.Add(factory.CreatePositionXY(6500001, 4950001))
> pcollection.Add(factory.CreatePositionXY(6534554.445, 4958445.342))
> Dim line As ILineString = factory.CreateLineString(pcollection)
> Dim geometryValue As GeometryValue = New
> GeometryValue(factory.GetAgf(line))
> insertCommand.PropertyValues.Add(New PropertyValue("geometry",
> geometryValue))
> insertCommand.Execute()
> Regards,
> Maksim Sestic
> Gavin Cramer wrote:
>> Hello, Maksim.  The "active" spatial context is a bit of a stale idea,
>> and might become deprecated.  Any provider that currently cares about it
>> actually sets it internally, based on the relevant geometric property's
>> spatial context association.
>> The association can be set when creating a schema definition via
>> FdoGeometricPropertyDefinition:: SetSpatialContextAssociation().
>> Gavin
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
>> Sent: Saturday, July 07, 2007 8:50 AM
>> Subject: [fdo-users] Defining SpatialContext - how and when?
>> Autodesk Map 3D 2007 / MS SQL Server 2005
>> I have problems inserting a new GeometryValue due to the "Default"
>> SpatialContext settings. "Default" SpatialContext has an envelope
>> (extents)
>> ranging from -2000000,-2000000 to 2000000,2000000, while my geometry
>> lies
>> way beyond default settings. Due to that fact, I keep receiving
>> following
>> error: "Error creating spatial context (null) (SRID=486518961), the WKT
>> provided does not match the catalog."
>> I tried to update Extents value on "Default" spatial context using
>> CreateSpatialContext command but it's not working (well, at least
>> nothing
>> changes in dbo.f_spatialcontextgroup table). Then I resorted to creating
>> a
>> new SC.
>> Now, I managed to create a new SpatialContext (named "MGI") with
>> associated
>> WKB string, proper extents settings, etc. Alas, I can not activate it
>> ActivateSpatialContext command does not affect present spatial contexts
>> within DataStore - ISpatialContextReader always returns IsActive = False
>> for
>> every SC present.
>> I think I'm doing something wrong here, just can't figure out exactly
>> what... :-) At what moment do I need to create custom SpatialContext
>> (before
>> or after creating feature schema?), and how do I apply newly established
>> SC
>> on present schema? How do I "force" my newly inserted geometric values
>> "conformant" to present SC?
>> Regards,
>> Maksim Sestic
>> View this message in context:
>> http://www.nabble.com/Defining-SpatialContext---how-and-when--tf4040281s
>> 18162.html#a11478212
>> Sent from the fdo-users mailing list archive at Nabble.com.
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://www.nabble.com/Defining-SpatialContext---how-and-when--tf4040281s18162.html#a11478979
View this message in context: http://www.nabble.com/Defining-SpatialContext---how-and-when--tf4040281s18162.html#a11498844
More information about the fdo-users
