[fdo-users] Compile problems, any ideas?
Gregor Mosheh gregor at hostgis.com
Wed Jul 11 13:00:05 EDT 2007
Traian Stanev wrote:
> You can go into the ThirdParty/apache directory and run the Xerces build
> by itself to see if it succeeds or not. There should be a small shell
> script that does the under ThirdParty/apache.
Your fix (with a twist) does work. And thanks a million!
( cd Thirdparty/apache/xml-xerces/c/src/xercesc ; ./configure )
./build_thirdparty.sh
Tracking down this bug a bit, it seems that Xerces's runConfigure is
buggy. "./runConfigure -p linux" just returns a usage message, and I
know for a fact that that's the proper calling syntax since I use xerces
on other machines for other projects.
Should I file this as a build-bug, or is it already fixed in the 3.2.2 beta?
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
More information about the fdo-users mailing list
