[fdo-users] OGR (postgis) and Autocad Map 2008
Jose Manuel C G
gis at mapas-sll.com
Fri Jun 8 07:17:10 EDT 2007
I've tried to connect to PostGIS with OGR inside Map 2008, and work.
I can see the schema, and the layer, but when I want to modify it
(check-out/ then modify/ check in), I get the next error:
2=Current OGR connection does not support update of existing features.
I try others OGR providers versions (3.2.1, 3.2.2,...), sometimes fail the
connection, too.
My question: Why? I can modify it with Qgis 0.8. Can I compile the source
code with add/delete/insert support?
View this message in context: http://www.nabble.com/OGR-%28postgis%29-and-Autocad-Map-2008-tf3889155s18162.html#a11024579
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
