[fdo-users] Unable to test PostGis provider
Bruno Scott
bscott at geomapgis.com
Tue Jun 26 10:00:43 EDT 2007
Hi all
i'm trying to test the new pre-release PostGis provider
But i am not able to do anything
In mapguide studio. when i try to create a new PostGis data connection i
have
no connection properties.
There is nothing in the log file...
In Autodesk Map 2008, when i try the same thing i got:
Unable to create connection to provider 'OSGeo.PostGIS.3.2'
Unable to load the FDO Provider: This application has failed to start
because the application configuration is incorrect. Reinstalling the
application may fix this problem.
It seems that the postgis fdo dll is not loading
My configuration
Windows XP sp2
PostGresSql 8.2.4 with PostGis 1.2.1
Mapguide Opensource 1.2 RC1
MapGuide Studio 2008 beta 1
Autodesk Map 2008
FDO PostGIS provider, build 3171
Path to postgreSQL/bin is in the first directory in the PATH Environment
variable
fdo dll are well copied in the fdo directory
Provider.xml is well configured
So i'm a bit stucked
I really like to test this provider
Bruno Scott
View this message in context: http://www.nabble.com/Unable-to-test-PostGis-provider-tf3982578s18162.html#a11306259
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
