[fdo-users] FDO component exception RDBMS
kgrootendorst at baird.com
Tue May 1 12:35:42 EDT 2007
Hello,
Using MGOS 1.1, FDO 3.2, MySQL 5.0.22, Win2000...
When setting up a MySQL connection through Studio, I keep getting the
following error:
An exception occurred in FDO component. RDBMS: Using unsupported buffer
type: 0 (parameter: 1)
Below is a dump from the server log. Does anybody have any idea as to how
to fix this?
Error: An exception occurred in FDO component.
RDBMS: Using unsupported buffer type: 0 (parameter: 1)
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpTestFeatureSourceConnection.Execute line 103 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
- MgFdoConnectionManager.Open line 815 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\common\manager\FdoConnectionManager.cpp
Thanks in advance.
Kevin
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070501/b578f3c1/attachment.html
More information about the fdo-users
