[fdo-users] FDO component exception RDBMS
kgrootendorst at baird.com
Wed May 2 13:26:55 EDT 2007
Brent,
Indeed you were right. I believe I may have been using a version 4 dll,
and it was being picked up in another directory.
To fix my specific problem, I copied the 'libmysql.dll' from my MySQL
folder (Program Files\MySQL\MySQL Server 5.0\bin) and placed in \Program
Files\MapGuideOpenSource\Server\Bin.
I also removed a copy of the dll that I had in my WINNT\System32 folder
(another user had suggested I place a copy there).
The MySQL connection is now working properly.
Thanks.
Kevin
"Brent Robinson" <brent.robinson at autodesk.com>
05/02/2007 10:24 AM
To
<kgrootendorst at baird.com>
cc
Subject
RE: [fdo-users] FDO component exception RDBMS
One case where this can happen is if the mysql client library
(libmysql.dll) is version 4 or earlier. Due to some data types that are
new to MySQL 5, a version 4 client can get the
?Using unsupported buffer type? error when talking to a version 5 server.
If this is the case, then replacing libmysql.dll with a version 5 one
should fix it. For a MapGuide installation, I?m not sure of the exact
location if libmysql but someone else on the [fdo_users] group would
likely know.
If you?re sure you have the right version of libmysql, there?s also the
chance that a libmysql from another directory is being picked up before
it, depending on the current path.
Brent.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of
Sent: Tuesday, May 01, 2007 12:36 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO component exception RDBMS
Hello,
Using MGOS 1.1, FDO 3.2, MySQL 5.0.22, Win2000...
When setting up a MySQL connection through Studio, I keep getting the
following error:
An exception occurred in FDO component. RDBMS: Using unsupported buffer
type: 0 (parameter: 1)
Below is a dump from the server log. Does anybody have any idea as to how
to fix this?
Error: An exception occurred in FDO component.
RDBMS: Using unsupported buffer type: 0 (parameter: 1)
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpTestFeatureSourceConnection.Execute line 103 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
- MgFdoConnectionManager.Open line 815 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\common\manager\FdoConnectionManager.cpp
Thanks in advance.
Kevin
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070502/0a12304f/attachment.html
More information about the fdo-users
