[fdo-users] King Oracle provider and Map 2008
Brad Nesom kidsmake6 at msn.com
Tue May 15 10:12:47 EDT 2007
That is OK Greg,
 I'm still trying to find where I put my round tuits.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Tuesday, May 15, 2007 8:46 AM
To: FDO Users Mail List
Subject: RE: [fdo-users] King Oracle provider and Map 2008
You point about Instructions being required is appropriate. The only
issue is finding the time....
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Monday, May 14, 2007 9:05 PM
To: fdo-users at lists.osgeo.org
That makes sense now. I will have to take a look at the providers.xml I
am
still waiting on the 3.2.2.60 though. I guess that will probably not be
available as beta. Maybe just the full release?
I may try it just so  I know how to do it. since the zip unzipped and
had
the same sub folder structure as the fdo/bin folder, and no
instructions, I
thought it was just a replacement for the bin folder. I won't make that
mistake again.
Brad
You need to be selective in what you do here. Replacing the whole bin
directory is probably not warranted. The biggest concern is the
providers.xml file. The providers.xml in the .tar file would have
invalid paths for your installation. You may have to either a) keep your
copy or b) merge the contents of the tar .xml file into your local file.
Otherwise, drop the binaries over top of what you have (after backing up
what you have) and overwrite the older files.
Try that and get back to us....
Greg
Sent: Monday, May 14, 2007 12:20 PM
To: 'FDO Users Mail List'
The fdo-3.2.2beta1-windows_bin_release.zip file replaces the existing
bin
folder? I attempted this and the add data tool would not run in 2008. I
have
replaced with the old bin and am back to working order. Does someone
know
what to do? I am not using the king provider. I want the sde provider in
the
new beta to test against my 9.2 sde.
Thanks
Brad
Sent: Wednesday, May 09, 2007 9:18 AM
FDO Providers compiled against FDO 3.2.2 are binary compatible with FDO
3.2.1 included with Autodesk Map 2008.
However, I have not personally tested the 3.2.2 version of the King
Oracle Provider. :-)
Greg
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Robert Fritz
Sent: Wednesday, May 09, 2007 8:52 AM
Subject: [fdo-users] King Oracle provider and Map 2008
on the web page of sl-king.com you can donwload a FDO Oracle Provider
which
was tested with Map 2007. There are newer releases of the provider for
3.2. and 3.2.2 available, but Map 2008 is not mentioned anymore. As far
as I
see now, Map 2008 is based on FDO 3.2.1.0 (according to FdoUserManager).
Did
anyone used the King Sl Oracle Provider with Map 2008? If so, which
version
(3.2. or 3.2.2)?
Regards, Robert
View this message in context:
http://www.nabble.com/King-Oracle-provider-and-Map-2008-tf3715512s18162.
html#a10393575
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
_________________________________________________________________
More photos, more messages, more storage-get 2GB with Windows Live
Hotmail.
http://imagine-windowslive.com/hotmail/?locale=en-us&ocid=TXT_TAGHM_migr
ation_HM_mini_2G_0507
More information about the fdo-users mailing list
