[fdo-users] ArcSDE 92
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Wed May 16 18:03:45 EDT 2007
Brad,
First of all please can you tell me if ArcSDEProvider.dll,
ArcSDEProvider91.dll and ArcSDEProvider92.dll are in the FDO\bin folder?
If yes, you could try something:
1) Remove pe91.dll, sde91.dll and sg91.dll from FDO\bin folder and
try to see the result. - doing that you will force ArcSDE provider to
use arcsde 92
2) Remove pe.dll, sde.dll and sg.dll from FDO\bin and copy back
pe91.dll, sde91.dll and sg91.dll folder and try to see the result. -
doing that you will force ArcSDE provider to use arcsde 91
Please let me know the result.
Thanks,
Romy.
_____
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Wednesday, May 16, 2007 5:53 PM
To: 'FDO Users Mail List'
Subject: RE: [fdo-users] ArcSDE 92
Hi Romy,
I don't know what you mean by the 9.1 libraries? I have 9.2 installed.
I have applied the esri service pack for 9.2 on both my client and on
ArcSDE.
I attached a screenshot of my bin folder. I do have the old 91 files in
there sde91.dll, sg91.dll and pe91.dll. I also have the newer sg, sde
and pe dlls.
You may notice that I am using map to make these connections. I was
using the mapguide OS to accomplish until my studio trial ran out and I
can't get the web studio to do anything.
Brad
Thanks for you help!
_____
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Romica
Dascalescu
Sent: Wednesday, May 16, 2007 4:24 PM
To: FDO Users Mail List
Hi Brad,
I did not have this issue when I tested.
Do you use arcsde 9.2 libraries (do you have also the 9.1 client)? Did
you apply the service pack from ESRI?
Thanks,
Romy.
_____
Sent: Wednesday, May 16, 2007 4:53 PM
Subject: [fdo-users] ArcSDE 92
I am still having an issue with arcsde 9.2 data in fdo 3.2.2.60 I can
see all numeric fields but there are no text fields. I am trying to
figure out if this is specific to my install or if anyone else has the
same issue?
Thanks
Brad
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070516/e3f15dbc/attachment.html
More information about the fdo-users
