[fdo-users] ArcSDE 92
Brad Nesom kidsmake6 at msn.com
Fri May 25 11:16:45 EDT 2007
I wish the arcsde fdo would be fixed for 9.2. Can anyone help?
Brad
  _____
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Thursday, May 17, 2007 11:32 AM
To: 'FDO Users Mail List'
Subject: RE: [fdo-users] ArcSDE 92
Romy,
  Foloowing your direction I have atteache dscreeen shots of each step
Fdo60text92.jp is step one and shows the data and table with only numeric
fields.
Fdo60text91.jpg is step two and shows no change.
Fdo60textarcmap.jpg shows that there are many fileds in the feature class in
arcsde.
Not sure what to look at to determine where the problem lies.
I also noticed just now that I cannot see a feature class that was loaded
via arcatalog (this registers it with sde automatically) as spatial data
objects (SDO_GEOMETRY) data type. Again not sure if this is relevant but
worth mentioning.
Brad
  _____
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Romica Dascalescu
Sent: Wednesday, May 16, 2007 5:04 PM
To: FDO Users Mail List
Brad,
First of all please can you tell me if ArcSDEProvider.dll,
ArcSDEProvider91.dll and ArcSDEProvider92.dll are in the FDO\bin folder?
If yes, you could try something:
1)       Remove pe91.dll, sde91.dll and sg91.dll from FDO\bin folder and try
to see the result. - doing that you will force ArcSDE provider to use arcsde
92
2)       Remove pe.dll, sde.dll and sg.dll from FDO\bin and copy back
pe91.dll, sde91.dll and sg91.dll folder and try to see the result. - doing
that you will force ArcSDE provider to use arcsde 91
Please let me know the result.
Thanks,
Romy.
  _____
Sent: Wednesday, May 16, 2007 5:53 PM
Hi Romy,
  I don't know what you mean by the 9.1 libraries? I have 9.2 installed. I
have applied the esri service pack for 9.2 on both my client and on ArcSDE.
I attached a screenshot of my bin folder. I do have the old 91 files in
there sde91.dll, sg91.dll and pe91.dll. I also have the newer sg, sde and pe
dlls.
You may notice that I am using map to make these connections. I was using
the mapguide OS to accomplish until my studio trial ran out and I can't get
the web studio to do anything.
Brad
Thanks for you help!
  _____
Sent: Wednesday, May 16, 2007 4:24 PM
Hi Brad,
I did not have this issue when I tested.
Do you use arcsde 9.2 libraries (do you have also the 9.1 client)? Did you
apply the service pack from ESRI?
Thanks,
Romy.
  _____
Sent: Wednesday, May 16, 2007 4:53 PM
Subject: [fdo-users] ArcSDE 92
I am still having an issue with arcsde 9.2 data in fdo 3.2.2.60 I can see
all numeric fields but there are no text fields. I am trying to figure out
if this is specific to my install or if anyone else has the same issue?
Thanks
Brad
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070525/1f366291/attachment.html
More information about the fdo-users mailing list
