[fdo-users] Using CircularArc in NEN1878 provider
Gavin Cramer
gavin.cramer at autodesk.com
Mon Oct 1 09:32:38 EDT 2007
Hello, Piet.
Arcs can only appear as curve segments. They do not actually derive
from FdoIGeometry. To get an FdoIGeometry from an arc, add the
FdoICircularArcSegment to an FdoCurveSegmentCollection and then create a
FdoICurveString. FdoICurveString is derived from FdoIGeometry. The
unit tests have some examples of this, e.g. see CreateCurveString() in
GeometryTest.cpp.
If you are trying to involve the arc in a polygon rather than a curve,
you can use the FdoCurveSegmentCollection to create an FdoIRing instead.
One or more FdoIRing values can be use to create an FdoICurvePolygon.
Gavin
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Piet Bibber
Sent: Monday, October 01, 2007 7:37 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Using CircularArc in NEN1878 provider
Hey,
The NEN1878 provides info as a CircularArc. I'm capabale of creating a
FdoICircularArcSegment, but have difficulties returning the IGeometry*
for
it (or the FdoByteArray*).
Question: How do I convert a FdoICircularArcSegment into a FdoIGeometry*
or
FdoByteArray*? (for usage in the readers GetGeometry function)
Note: Turning the FdoICircularArcSegment into Geometry via Envelope
doesn't
seem to work; or returning the 3 points as part of a CurveString. (But I
might be overlooking something)
Thanks in advance
Piet
View this message in context:
http://www.nabble.com/Using-CircularArc-in-NEN1878-provider-tf4547783s18
162.html#a12977578
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
