[fdo-users] Improving performance for NEN1878 provider, howto?
    Piet Bibber
    piet.bibber at gmail.com
    Thu Oct  4 06:17:19 EDT 2007
Dan,
SelectAggregates does instanciate the OptimizedAggregateReader  (at the
bottom of the Execute command).
Where I believe it is very slow is in getting data (through the IsNull and
GetData methods);
The dialog with "Polulating Feature Cache" is on screen during 3 to 5
seconds; the same dataset in sdf takes sub seconds to load. The "Polulating
Feature Cache" dialog doesn't even appear.
My features are all in memory, no disk access is needed, yet is multiple
times slower.
i must be doing something wrong.
When I return true to IsNull (and avoid the GetData call), its still
slow....
What else can I do to trace performance or to make GetData faster?
Thanks for the help so far
Piet
On 10/1/07, Dan Stoica <dan.stoica at autodesk.com> wrote:
>  Indeed, OptimizedAggregateReader is the place. Make sure your
> SelectAggregates command is instantiating such a reader.
> Dan.
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Piet Bibber
> *Sent:* Monday, October 01, 2007 10:16 AM
> *To:* FDO Users Mail List
> *Subject:* Re: [fdo-users] Improving performance for NEN1878 provider,
> howto?
> Robert, Badreddine, Gavin
> I do provide the extends and counts in Nen1878OptimizedAggregateReader. Is
> that what you refer to?
> Piet
> On 10/1/07, *Robert Fortin* <robert.fortin at autodesk.com> wrote:
> Badreddine,
> Isn't it the combination of count and spatialExtents that need to be
> optimized?
> I believe Map looks for the equivalent of
> Select SpatialExtents(geometry), count(*)  from <class>
> RF
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Badreddine
> Karoui
> Sent: Monday, October 01, 2007 9:42 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Improving performance for NEN1878 provider,
> howto?
> Hi,
> You may want to implement the FdoISelectAggregates command plus the
> SpatialExtents and Count functions. If these two functions are not
> implemented, then Map will scan all the geometries to find the minimum
> bounding rectangle of all the data.
> Badreddine
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Piet Bibber
> Sent: Monday, October 01, 2007 7:46 AM
> Subject: [fdo-users] Improving performance for NEN1878 provider, howto?
> Hello,
> My NEN1878 provider is almost done, but performance is not so fantastic
> when
> reading the geometry; reading the schema is alright.
> That is stange, as I cache in the geometry when I read the schema
> (NEN1878
> schema discovery requires a full file scan; no seperate schema header).
> (The
> schema is read within 3 seconds for a 2.3MB file, including the geometry
> and
> attributes (all in memory (using STL)).
> The SDF and SHP all seem so fast :-)
> Map 3D seem to spend most of his time caching in the geometry (see
> source
> code below)
> I based my provider on the SHP provider, the reader seem to use
> FDO_READER
> template, but I can't find where that points to. Maybe there are better
> optimized readers.
> Thanks.
> Piet
> Excerpt from the source files:
>    FdoByteArray * CreateCachedGeometry(FdoByteArray* fgfByteArray_I)
>        FdoByteArray*   fgfByteArray = fgfByteArray_I; // it may be
> reallocated
>        int             count = mFeature->GetNumPoints();
>        FdoInt32        numPointOrds = 2;
>        FdoInt32        numBytesForOrdinates = numPointOrds *
> sizeof(double)
> * count;
>        FdoInt32        numParts = 0;
>        FdoGeometryType fdoGeomType  = GetFdoGeometryType();
>        FdoInt32        dimensionality = FdoDimensionality_XY;
>        FdoInt32        numPositions   = mFeature->GetNumPoints();
>        fgfByteArray->Clear();
>        fgfByteArray = FdoByteArray::Append(fgfByteArray,
> sizeof(fdoGeomType), (FdoByte *) &fdoGeomType);
>        switch (fdoGeomType)
>        case FdoGeometryType_None:
>            break;
>            case FdoGeometryType_Point:
> sizeof(dimensionality), (FdoByte*)&dimensionality);
> numBytesForOrdinates,   (FdoByte*)mFeature->GetPoints());
>                    break;
>            case FdoGeometryType_LineString:
> sizeof(dimensionality), (FdoByte *) &dimensionality);
> sizeof(count),
> (FdoByte *)&count);
> numBytesForOrdinates, (FdoByte *)mFeature->GetPoints());
>                    break;
>            default:
>            throw
> FdoException::Create(FdoException::NLSGetMessage(FDO_NLSID(FDO_10_UNSUPP
> ORTEDGEOMETRYTYPE)));
>            return (fgfByteArray);
> // Returns pointer to vector of DoublePoints
> inline DoublePoint* Nen1878Feature::GetPoints()
>    return (&mCoordinates[0]);
> http://www.nabble.com/Improving-performance-for-NEN1878-provider%2C-howt
> o--tf4547817s18162.html#a12977669
> Sent from the fdo-users mailing list archive at Nabble.com<http://nabble.com/>
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20071004/7ec6a110/attachment.html
More information about the fdo-users
