[fdo-users] FdoMessage.h missing from svn?
John Pulles
john.pulles at geodan.nl
Tue Oct 23 10:59:33 EDT 2007
Greg Boone schreef:
> Have you solved this? I recommend a full clean-rebuild to try and solve
> it. Make sure you have taken all the files from the FDO SVN.
Hi Greg,
Thanks for your reaction. I've tried to rebuild in a clean environment
by still get the following error for the Managed FDO part:
Updating Assembly Version Information for
..\Bin\Win32\Debug\OSGeo.FDO.Common.dll
Error reading input.
System.ArgumentException: File does not exist.
Parameter name: filename
at MattGriffith.UpdateVersion.RunUpdateVersion.ReadFile(String filename)
at MattGriffith.UpdateVersion.RunUpdateVersion.GetInput(Options options)
at MattGriffith.UpdateVersion.RunUpdateVersion.Main(String[] args)
Project : error PRJ0019: A tool returned an error code from "Updating
Assembly Version Information for ..\Bin\Win32\Debug\OSGeo.FDO.Common.dll"
No idea what it comes from (it seems the FDO\Managed\Project's are not
being build), but it's fairly blocking to make a debug version.
Kind regards,
John
> Greg
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of John Pulles
> Sent: Thursday, October 11, 2007 10:47 AM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] FdoMessage.h missing from svn?
> Greg Boone schreef:
>> I believe you will have to build the FDO API before building the
> PostGIS
>> provider. PostGIS cannot be built off of the FDO SDK files.
>> Follow the instructions in OpenSourceBuild__README.txt on how to build
>> FDO.
>> Here is a quick step by step set of calls for a debug release:
>> 1) Call setenvironment.bat
>> 2) Call build_thirdparty -w=fdo -c=debug
> Thanks Greg,
> The "missing" file is indeed built on build_thirdparty.
>> 3) Call build -w=fdo -c=debug
> I think I have followed the README document, but am getting the
> following error on the MgCommon subproject here:
> Target MgCommon:
> D:\Programs\Microsoft Visual Studio
> 8\Common7\IDE\..\..\vc\vcpackages\vc
> build.exe E:\fdo\Fdo\Managed\Project\MgCommon.tmp_Debug_Win32.vcproj
> "Debug|Win3
> 2"
> "Updating As
> Done building target "MgCommon" in project "FDO.sln" -- FAILED.
> Is this familiar to anyone?
> Regards,
> John.
>> Sent: Wednesday, October 10, 2007 10:56 AM
>> Subject: [fdo-users] FdoMessage.h missing from svn?
>> Hi list,
>> I'm trying to build fdo postgis from the subversion code tree, but am
>> running into problems. It seems that the FdoMessage.h file is missing
>> from the repository; it is referenced in
>> https://svn.osgeo.org/fdo/trunk/Fdo/Unmanaged/Inc/Common/Exception.h
> but
>> not present anywhere.
>> In a source archive this file can be found in the Fdo\Unmanaged\Inc
>> folder, so it probably needs to be added to the repository.
>> Kind regards,
>> John
John Pulles
Geodan IT b.v.
Buitenhaven 27-A
5211TP 's-Hertogenbosch
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)73 - 692 5150
Postadres / mailing address
President Kennedylaan 1
1079MB Amsterdam
E-mail: john.pulles at geodan.nl
Website: http://www.geodan.nl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20071023/53fc3744/attachment.html
More information about the fdo-users
