[fdo-users] FDO trunk build dies at Thirdparty/curllib (windows)
Jack Lee
jack.lee at autodesk.com
Tue Oct 30 23:22:37 EDT 2007
Hi Jackie,
Is perl installed and in your path?
Also, check the log file
C:\OsGeo\FDOBuils\Thirdparty\openssl\BuildLog.htm
It should show the files being generated.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, October 30, 2007 10:54 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] FDO trunk build dies at Thirdparty/curllib (windows)
Hi Jack,
Yes i did run setenvironment.bat before build_thirdparty.bat
The "inc32" directory is not being created.
Regards,
Jackie Ng
AEC Spatial Pty Ltd / AEC Systems Pty Ltd
Winner: 2007 Victorian Spatial Excellence Awards (Spatially enabling businesses)
D: (03) 9890 9337
M: 0405 402 434
P: 1300 368 609
F: 1300 362 140
Website: http://www.aecsystems.com.au</exchweb/bin/redir.asp?URL=http://www.aecsystems.com.au>
E-store: http://estore.aecsystems.com.au</exchweb/bin/redir.asp?URL=http://estore.aecsystems.com.au>
From: fdo-users-bounces at lists.osgeo.org on behalf of Jack Lee
Sent: Wed 10/31/2007 13:42
Hi Jackie,
The inc32 directory and the files in that directory are generated by the build.
Did you try running setenvironment.bat before running build_thirdparty.bat?
-----Original Message-----
Sent: Tuesday, October 30, 2007 10:19 PM
To: fdo-users at lists.osgeo.org
Hi Jack,
The whole "inc32" directory doesn't exist.
- Jackie
Jack Lee-3 wrote:
> Hi Jackie,
> Check if the file
> C:\OsGeo\FDOBuild\Thirdparty\openssl\inc32\openssl\rsa.h
> exists?
> If the file does not exist, try running setenvironment.bat before running
> build_thirdparty.bat.
> Sent: Tuesday, October 30, 2007 6:52 PM
> (windows)
> Hi Jack,
> Yes that file does exist, its contents are:
> link ../../crypto/rsa/rsa.h
> Which if computed from that path would mean it's looking for:
> C:\OSGeo\FDOBuild\Thirdparty\openssl\crypto\rsa\rsa.h
> Which also exists.
> - Jackie
> Jack Lee-3 wrote:
>> Hi,
>> Does the file
>> C:\OSGeo\FDOBuild\Thirdparty\openssl\include\openssl\rsa.h
>> exist?
>> Sent: Monday, October 29, 2007 11:16 PM
>> Subject: [fdo-users] FDO trunk build dies at Thirdparty/curllib (windows)
>> Hi List,
>> I've been trying to build FDO from the trunk and build_thirdparty.bat is
>> dying at the curllib component. This is the output I get when running
>> build_thirdparty.bat, Any help would be appreciated. Cheers.
>> - Jackie
>> Build release Thirdparty files
>> Build started 30/10/2007 2:14:03 PM.
>> __________________________________________________
>> Project "C:\OSGeo\FDOBuild\Thirdparty\Thirdparty_fdo.sln" (Build
>> target(s)):
>> Target ValidateSolutionConfiguration:
>> Building solution configuration "release|Win32".
>> Target Build:
>> Target XercesLib:
>> C:\Program Files\Microsoft Visual Studio
>> 8\Common7\IDE\..\..\vc\vcpackages\vcbuild.exe
>> C:\OSGeo\FDOBuild\Thirdparty\apache\xml-xerces\c\Projects\Win32\VC8\xerces-all\XercesLib\XercesLib.vcproj
>> "Release|Win32"
>> Target cppunit:
>> C:\OSGeo\FDOBuild\Thirdparty\cppunit\src\cppunit\cppunit.vcproj
>> "Release|Win32"
>> Target TestRunner:
>> C:\OSGeo\FDOBuild\Thirdparty\cppunit\src\msvc6\testrunner\TestRunner.tmp_Release_Win32.vcproj
>> "Release|Win32"
>> Deleting file
>> "C:\OSGeo\FDOBuild\Thirdparty\cppunit\src\msvc6\testrunner\TestRunner.tmp_Release_Win32.vcproj".
>> Target cppunit_dll:
>> C:\OSGeo\FDOBuild\Thirdparty\cppunit\src\cppunit\cppunit_dll.vcproj
>> "Release|Win32"
>> Target Localization:
>> C:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c\Projects\Win32\VC6\Utils\Localization\Localization.tmp_Release_Win32.vcproj
>> "Release|Win32"
>> Deleting file
>> "C:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c\Projects\Win32\VC6\Utils\Localization\Localization.tmp_Release_Win32.vcproj".
>> Target AllInOne:
>> C:\OSGeo\FDOBuild\Thirdparty\Thirdparty_fdo.sln : warning
>> MSB3422:
>> Failed to retrieve VC project information through the VC project engine
>> object model. Unable to determine default tool for the specified file
>> configuration.
>> MSB3425:
>> Could not resolve VC project reference
>> "C:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c\Projects\Win32\VC6\Utils\Localization\Localization.vcproj".
>> C:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c\Projects\Win32\VC6\AllInOne\AllInOne.tmp_Release_Win32.vcproj
>> "Release|Win32"
>> Deleting file
>> "C:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c\Projects\Win32\VC6\AllInOne\AllInOne.tmp_Release_Win32.vcproj".
>> Done building target "AllInOne" in project "Thirdparty_fdo.sln".
>> Done building target "Build" in project "Thirdparty_fdo.sln".
>> Done building project "Thirdparty_fdo.sln".
>> Build succeeded.
>> Time Elapsed 00:00:17.18
>> Build started 30/10/2007 2:14:20 PM.
>> Project "C:\OSGeo\FDOBuild\Thirdparty\Thirdparty_sdf.sln" (Build
>> target(s)):
>> Target Build:
>> Target Sqlite3:
>> C:\OSGeo\FDOBuild\Thirdparty\Sqlite3.3.13\Sqlite3.vcproj "Release|Win32"
>> Build succeeded.
>> Time Elapsed 00:00:00.70
>> Build started 30/10/2007 2:14:21 PM.
>> Project "C:\OSGeo\FDOBuild\Thirdparty\openssl\openssl.sln" (Build
>> target(s)):
>> Target Build:
>> Target openssl:
>> C:\OSGeo\FDOBuild\Thirdparty\openssl\openssl.vcproj "Release|Win32"
>> Build succeeded.
>> Time Elapsed 00:00:00.59
>> Build started 30/10/2007 2:14:22 PM.
>> Project "C:\OSGeo\FDOBuild\Thirdparty\libcurl\lib\curllib.sln" (Build
>> target(s)):
>> Target Build:
>> Target curllib:
>> C:\OSGeo\FDOBuild\Thirdparty\libcurl\lib\curllib.vcproj "Release|Win32"
>> c:\osgeo\fdobuild\thirdparty\libcurl\lib\urldata.h(55): fatal
>> error
>> C1083: Cannot open include file: 'openssl/rsa.h': No such file or
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> .\md5.c(337): fatal error C1083: Cannot open include file:
>> 'openssl/md5.h': No such file or directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> error
>> directory
>> BSCMAKE : error BK1506: cannot open file '.\Release\connect.sbr':
>> No
>> Done building target "curllib" in project "curllib.sln" -- FAILED.
>> Done building target "Build" in project "curllib.sln" -- FAILED.
>> Done building project "curllib.sln" -- FAILED.
>> Build FAILED.
>> Time Elapsed 00:00:17.07
>> There was a build error executing action: Build
>> There was a build error.
>> View this message in context:
>> http://www.nabble.com/FDO-trunk-build-dies-at-Thirdparty-curllib-%28windows%29-tf4716181s18162.html#a13481827
>> Sent from the fdo-users mailing list archive at Nabble.com.
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://www.nabble.com/FDO-trunk-build-dies-at-Thirdparty-curllib-%28windows%29-tf4716181s18162.html#a13499494
View this message in context: http://www.nabble.com/FDO-trunk-build-dies-at-Thirdparty-curllib-%28windows%29-tf4716181s18162.html#a13501761
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20071030/647381d6/attachment-0001.html
More information about the fdo-users
