[fdo-users] Arcsde sdo update
Jack Lee jack.lee at autodesk.com
Wed Oct 31 07:31:29 EDT 2007
Yes, 9.2 support is in the 3.2.x branch.
Which documentation are you referring to?
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Wednesday, October 31, 2007 5:05 AM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] Arcsde sdo update
"This will definitively be available in the coming weeks in the OpenSource
side under the 3.2.x branch."
Is the 9.2 support already in the 3.2.x branch?
I don't see anything in the documentation that would tell that the ArcSde
provider support 9.2
Thanks Bruno
bradgisoklah wrote:
> FYI there are new sde binaries and libs for the client with the new 9.2
> sp2.
> Download the zip and extract to the client install folder.
> http://support.esri.com/index.cfm?fa=downloads.patchesServicePacks.viewPatch
> &PID=66&MetaID=1269#install-ncWindows
> From: Robert Fortin [mailto:robert.fortin at autodesk.com]
> Sent: Thursday, April 12, 2007 1:01 PM
> To: Brad Nesom
> Brad,
> We are looking into how to retro fit 9.2 support for Map 2008 (if that
> is your question).
> OpenSource side under the 3.2.x branch.
> RF
> From: Brad Nesom [mailto:kidsmake6 at msn.com]
> Sent: Thursday, April 12, 2007 10:37 AM
> To: Robert Fortin
> Robert,
>  As I am having difficulty with moving my data from sde binary to sdo, I
> am getting particularly interested in the arcsde fdo provider as being
> my longer term solution.
> I just re-read your post and have found the following information.
> http://support.esri.com/index.cfm?fa=knowledgebase.systemRequirements.co
> mpat
> ibility
> I am wondering if it would not be fairly easy to integrate support for
> 9.2 into the same model that fdo 3.2 is using. As I have been testing
> there seems to be no table read access problems or connection problems.
> However the functioning part of fdo 3.2 is the field access to numeric,
> date, and int32. The only non-functioning part(read only is all I have
> tested.) is the string field access. Put simply I cannot see string
> fields in sde 9.2 everything is is good.
> Is there a possibility that this cold be implemented for an upcoming
> release?
> Sent: Wednesday, April 04, 2007 8:11 AM
> To: Brad Nesom
> Map 2008 will have support for sde 9.1.  The ESRI documentation is not
> obvious about using 9.1 client component with 9.2 server.  Primary tests
> has shown that it will work but that's probably not a configuration we
> want to recommand.  At the same time, by the time you will get Map 2008
> (pretty soon), you will be able to get FDO opensource version for sde
> 9.2.
> MGOS (and later related release of MGE) will integrate 9.2 provider.
> RF
> Sent: Wednesday, April 04, 2007 9:00 AM
> To: Robert Fortin
> We are a subscription map on 2007 right now. I will upgrade when 08
> arrives.
> I am considering implementing mgos. That is what I am working on here.
> We have esri arcgis server advanced enterprise (which means sde, ims,
> gis server). We are trying to get more familiar with the technology and
> decide what we will implement.
> I have a beta site profile but haven't requested the map 08 just because
> of time restraints. My 07 connects to my 92sde (unsupported) with the
> limitations mentioned earlier.
> Brad
> Sent: Wednesday, April 04, 2007 7:48 AM
> To: Brad Nesom
> Brad,
> I meant: what app are you using? Map 2008 Beta, MapGuide OpenSource or
> MapGuide Enterprise, etc.
> RF
> Sent: Tuesday, April 03, 2007 10:07 PM
> To: Robert Fortin
> I am using 9.2 and oracle 10r2.05
> From: "Robert Fortin" <robert.fortin at autodesk.com> Yes.  That's one part
> of it.  We also didn't want to impose 9.1 client component on the user.
> So we are creating a front end dll loaded that will load the correct
> provider depending on the presence of the arcSDE components.  It will
> try to load 9.2 components first and if it doesn't succeed, it will try
> the 9.1 components.
> What are you using? we can probably give you something to try out.
> RF
>    _____
> Sent: Tuesday, April 03, 2007 2:56 PM
> To: Robert Fortin
> Yes I don't have any problem with the connection. The only problem is
> that all number fields show up but no text fields do.
> So you are just reworking the dlls to link to the new libs?
> Brad
>    _____
> Sent: Tuesday, April 03, 2007 1:01 PM
> To: Brad Nesom; fdo-users at lists.osgeo.org
> Brad,
> Did you try 9.1 client with 9.2 server?
> We are working on linking with the 9.2 client libs.  Once we are done,
> it should run with 9.1 or 9.2 client component.
> RF
>    _____
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Tuesday, April 03, 2007 12:39 PM
> Subject: [fdo-users] Arcsde sdo update
> Is anyone planning on updated the arcsde fdo? I still can't access my
> text columns on my 9.2 sde data. As far as I can tell everything else is
> hunky.
> Thanks
> Brad
> _________________________________________________________________
> Mortgage refinance is Hot. *Terms. Get a 5.375%* fix rate. Check savings
> https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&se
> arch=mortgage_text_links_88_h2bbb&disc=y&vers=925&s=4056&p=5117
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/RE%3A-Arcsde-sdo-update-tf3567561s18162.html#a13505188
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
