[fdo-users] New FDO Provider and using it in Map 3D
Jason Birch
Jason.Birch at nanaimo.ca
Tue Sep 11 23:40:29 EDT 2007
Robert, when you say that it's specific to Map, does that mean that the same mechanism will not work with MapGuide Studio?
I'm not sure what would be the best place for it... but since it requires linking to Map, probably one of the options you suggest. I'd suggest as a download, so that it's generally available prior to 2009. Though... it is archived on Nabble :)
Jason
Subject: Re: [fdo-users] New FDO Provider and using it in Map 3D
Jason,
I got a noitification from the server to make sure the email had not been posted by an automated process. This might explain why you didn't get it.
You are right. This is specific to map and I'm not sure if it fit on the os site. But on the other side, it is valuable to anybody building provider and wanting to create custom dialog in map.
It could be posted on autodesk site too or provided as a sample with Map.
I'm open to suggestion.
RF
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-users/attachments/20070911/e530f517/attachment.bin
More information about the fdo-users
