[fdo-users] Unicode (nvarchar) support for MS SQL Server
Brad Nesom
kidsmake6 at msn.com
Wed Sep 12 01:20:29 EDT 2007
I had to fix this in my database by specifying unicode_string=false the same issue exists with oracle and the arcsde 9.2 fdo provider.
Brad
> Date: Tue, 11 Sep 2007 07:25:06 -0700> From: max at geoinova.com> To: fdo-users at lists.osgeo.org> Subject: [fdo-users] Unicode (nvarchar) support for MS SQL Server> > > Hi all,> > I'm using FDO 3.2 (managed), Map 2007 and Microsoft SQL Server-based> DataStore. As far as I understand, FDO's Fdo.Schema.DataType.DataType_String> is mapped to MS SQL varchar() type. Alas, I need to store UTF-8 (Unicode)> based strings and that's not possible via present mapping.> > Is it possible to change present Fdo.Schema.DataType.DataType_String mapping> to nvarchar() instead of varchar()? > > With kindest regards,> Maksim Sestic> -- > View this message in context: http://www.nabble.com/Unicode-%28nvarchar%29-support-for-MS-SQL-Server-tf4422980s18162.html#a12615983> Sent from the fdo-users mailing list archive at Nabble.com.> > _______________________________________________> fdo-users mailing list> fdo-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/fdo-users
_________________________________________________________________
Capture your memories in an online journal!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070912/f208039c/attachment.html
More information about the fdo-users
