[fdo-users] RE: Unable to test PostGis provider
Maciej Skorczewski
maciej.skorczewski at procad.pl
Wed Sep 12 08:27:57 EDT 2007
Hi Jason !
it works...this what have i make whit this:
1. Install new PostgreSQL database 8.2.4.1 + PostGIS.
2. add postgis*.dll , edit providers.xml
...so te problme what whit postgreSQL version...before it was 8.1.x
Dependency Walker show that it was some file missing...and it was file
from PostgreSQL 8.2.4.1 (thera are much more files :)
now it works fine...
uuufffffff. :)
thx for all.
ps. now lets test it whit Map3D 2008
maciek skorczewski
Jason Birch pisze:
> Hi,
> On the server machine, you need to have the postgresql/bin directory in the system path (makse sure not in user path), first in the path is probably safest. Others have found that sometimes you have to move specific DLLs from that directory into the fdo/bin directory, but I haven't had to do that myself.
> Depending on the version of the provider that you have downloaded, you may also need to install the MSVC++ 2005 SP1 Runtime, available from the Microsoft site.
> Jason
More information about the fdo-users
