[fdo-users] "Number of points must be 0 or >3" Error
Dan Stoica dan.stoica at autodesk.com
Mon Sep 17 11:54:04 EDT 2007
If this is the case then the error message is correct: the FDO polygons
must be be closed, which means at least 4 points.
Dan.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Monday, September 17, 2007 11:50 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] "Number of points must be 0 or >3" Error
Frank,
There was a problem :-) in my polygon geometry, but this is a lesser
problem. I was just pointing out to a typo in resulting error message.
Regards,
Maksim Sestic
Frank Warmerdam-2 wrote:
> Maksim Sestic wrote:
>> Hi all,
>> Funny thing - I just received this error while checking in some
polygons.
>> Should it state ">=3", rather than ">3", since there are triangular
>> polygons?
>> Regards,
>> Maksim Sestic
> Maksim,
> Perhaps the polygons have to be explicitly closed, and so a 3 vertex
> polygon would require a fourth point (the first again at the end)?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context:
http://www.nabble.com/%22Number-of-points-must-be-0-or-%3E3%22-Error-tf4
467236s18162.html#a12738567
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
